I'm not sure. The 11v has to be coming from the area of the op-amp since there is no voltage on the other end of it and nothing else except for one resistor is connected to it. The other resistor (R412) goes to ground (confirm).
It may be possible for the voltage to be higher than it should be if R412 is open or out of tolerance (check it) but I wouldn't expect it to be near -11v.
Im rebuilding that entire section of the amp since the op-amps were new and had nothing but problems with this amp..
D402 is marked D4 here are the readings i get on it
im using the top leg as leg 1
Legs 1-2:0.562
Legs 1-3:OL
Legs 2-3:OL
Probes reversed
Legs 1-2:OL
Legs 1-3:0.560
Legs 2-3:1.052
Does this appear to be good ?
Legs 1-2:0.562
Legs 1-3:OL
Legs 2-3:OL
Probes reversed
Legs 1-2:OL
Legs 1-3:0.560
Legs 2-3:1.052
Heres the op-amps i orderd from future wil theese work??
NE5532AD8G | NE Series 9 V/us 22 V SMT Dual Low Noise Operational Amplifier - SOIC-8 | ON SEMICONDUCTOR - Future Electronics
The only time that a Zener will be a regulator by itself is when its terminals are directly connected to the power supply terminals of the component for which the voltage is being regulated. In most cases, a Zener is only a reference for a larger circuit that ultimately produces the regulated voltage. The 7805 is a standalone regulator.
Re-read the MTX 7801 page for descriptions of the voltage regulators used in the MTX amps for the op-amp power supplies.
I replaced D201 and i dont get this amp..
1 side of R414: 0.70 volts
Other side is: -11.45 volts
I replaced both op-amps with new checked for solder bridges and found none..
Is there another section of this amp i should be checking ??
R412 one side goes to ground
The other side has -11.38 volts
Replaced the op-amp again..
This time i get 0.72 volts on 1 side of R414 and 0 volts on the other side..
Heres what i have on the op-amp closet to the opto_couplers
Pin 1:-14.23
Pin 2:0.15
Pin 3:0
Pin 4:-15.55
Pin 5:-13.89
Pin 6:0
Pin 7:4.40
Pin 8:15.01
The other NE5532
Pin 1:0
Pin 2:0
Pin 3:0
Pin 4:-14.89
Pin 5:0
Pin 6:0
Pin 7:0
Pin 8:15.03
Pin 1:-14.23
Pin 2:0.15
Pin 3:0
Pin 4:-15.55
Pin 5:-13.89
Pin 6:0
Pin 7:4.40
Pin 8:15.01
The other NE5532
Pin 1:0
Pin 2:0
Pin 3:0
Pin 4:-14.89
Pin 5:0
Pin 6:0
Pin 7:0
Pin 8:15.03
I didn't see that you replaced it. I thought it was still out. What were the voltages with the op-amp out?
Sometimes problems in the circuit can destroy every op-amp you install untill the problem is found. It's virtually impossible to have multiple bad op-amps (before installing them).
- General Interest
- Car Audio
- MTX TA 81001
