hi valentine.
plz. can u share the 600wa 1500w high resolution pcb lay out tnz.
what is this amp?
original project- Amplificador Asiatico Con Super Driver de 600W a 1500W + PCB
OK
OK
Hello
greetings in post 6 pcb can be zoomed to orignal size and component layout is clear enough for any one interested in making this amp i think amp is easy enough to make AB class heat and effiency not good if anyone needs high power D CLASS is better
thats also not hard to make TRY IT
warm regards
andrew lebon
warm regards
andrew lebon
Another one to diy
warm regards
andrew lebon
Do you have schematic for this.?
- MTE AUDIO AMP
