Transformer help
I got how to wire the toroidal transformer for use in powering my cd-rom controller. I plan on using an R-core for the OPUS. Before I destroy the LCPS could someone tell me which wires I should connect to which LCPS inputs? Which wires I connect to which AC source? Neutral? Hot?
Thank you
Darren
Thank you
Darren
Re: Transformer help
For 120V mains, you join the Red and Green leads together and to one mains connection, and the Yellow and Orange leads together and to the other mains connection.
For the LCPS, use the White and Black secondaries; White/White/Black/Black in that order.
If you are not using the Blue and Brown secondaries (18V), be sure to tie them off so they do not short.
DarrenWadsworth said:I got how to wire the toroidal transformer for use in powering my cd-rom controller. I plan on using an R-core for the OPUS. Before I destroy the LCPS could someone tell me which wires I should connect to which LCPS inputs? Which wires I connect to which AC source? Neutral? Hot?
Thank you
Darren
That's an interesting looking transformer you've got there. Where did you get it? Another nice thing about your transformer is that you can use the 18 V secondaries to power the LCBPS for the Ballsie.
Thank you
Darren
When I connected the Toroidal I bought from Twisted Pear, my DMM show the output voltage as 17.5vac.
Was supposed to be:
(115V+115V prim. / 15V+15V 25VA sec.)
Did I connect it wrong?
I'm using it for the cd-rom controller which the maker just told me that 17.5 could be too much for the voltage regulator.
He recc 12v but told me that 15 would be ok. I guess 17 is too much.
Any Ideas?
Thank you
Darren
Was supposed to be:
Any Ideas?
Thank you
Darren
I would have to look after work. If I give you the part number would that help? This thing produces 12 and 5 volts for the cd-rom.
Do you think maybe its the one by the rectifier diodes?
Or?
Darren
Or?
Darren
BrianDonegan said:Our plan is to make another receiver based on the WM8805 to allow up to 8 S/PDIF sources.
Do you have a timeframe of the new receiver bóard? This would be a great addition to the lineup no doubt.
BrianDonegan said:Looks like an LM7812 and 7805. They can handle the voltage, but probably not without a heatsink. Maybe you shoudl try a different trafo.
I verified that the VREG next to the rectifier diodes is a 7805. You're good!
Would it fry it if I attach bend it up and attach a generic TO220 heat sink (which I can get locally) to that VREG? What about the other non-heatsinked part?
If you could reply today it would be great as I am going to try to get the whole thing running by tonight.
Thanks, very much.
Darren
hi,
I've been using the opus dac through usb for a few days now. I was only using it on my main computer, which is running Vista, and it's been running fine. Today I tried plugging in the usb into 2 windows xp computers, but all i get is static and heavy interference with the music. Anyone have this problem?
hi,
- More Vendors...
- Twisted Pear
- Mr White's "Opus", designing a simple balanced DAC
