I am not actually collecting money yet, but thank you. I will add you to the list. Payment requests will probably go out middle of next week.Pete, I think I may have to bite on two boards. I'll make payment via paypal as per your schedule in the first post unless I hear otherwise shortly.
I just haven't got to finishing my own version, so might as well use yours .
Same thing applies to everyone else - please sign up at your convenience, but it is easier for me to keep track if I can start the payment process for everyone at the same time, thanks.
I had you on the list as 4 boards requested, and 2 shipped. Did you receive 2 boards?Pete, 6 boards please.
Thank you!
Noted.I origanly requested one board but would like 2.
Bill
Yes, 2 boards arrived the other day, many thank's for that.
If it poses no trouble I'd like 6 more, otherwise I'll stick with what I said .-)
Hi Pete,
I have assembled a new CP using the parts you listed below except I used MUR860G for the diodes. For some reason, I can't seem to get it to adjust the voltage. Are there some resistor changes that need to be made as well?
Thanks, Terry
Thanks, Terry
PMI said:Terry,
Were you interested in a higher voltage Cap Multiplier at one point? I had to clear my mail a couple times, and I am sure I missed some questions.
This is a summary of the parts I plan to use to get there:
Rectifier diode: MSR860/MSRF860 (300V reverse voltage)
Pass Transistors: IRF5210PBF/IRF3710PBF (up to 100V)
BJT: KSC1845/KSA992 (120V)
Mosfets: ZVN3310/ZVP3310 (up to 100V)
I have only tested with the MSRF860 so far, so any comments are welcome.
The jfet only sees 1/2 the output voltage, so the 35V-rated J112 is good for up to 70V. It can also be replaced with a 5.6V constant current diode to get over 70V.
Pete
Hi Pete,
Thanks, Terry
Thanks, Terry
PMI said:Terry,
Were you interested in a higher voltage Cap Multiplier?
Pete
- Group Buys
- Mr Evil's Capacitance Multiplier Power Supply PCB
