MPP
I have now build the circuit. It worked right away without problems. I measured input offset in both channels to be under 0,5mV with a 5 Ohm cartridge. Fanatics may wish to trim that away and this is certainly possible.
"Anyway, the impedance of the feedback network can be reduced".
Yes, as per the hint above in 11183.
On the other hand, the diode/resistor network establishes bias and
feedback at the same time. I consider this as a practical problem.
You are using a two transistor input stage - long tailed pair without
a tail
- is this not the same noise penalty as using a diff amp input ?
Compare to Zetex app note https://www.diyaudio.com/forums/ana...ra-low-noise-mc-head-amp-160.html#post5939775
where the coupling caps can be left away.
Thats right But the Zetex Transistors i use have less then 2 Ohm Rbb. So the total Noise from that chain inclusive the 1Ohm is under 5 Ohm. My LYRA Atlas has 5 Ohm impedance. So Not considering the influence the Feedback resistors have it worcence the Noise of the cartridge by only 3 dB. I do Not know what will Happen to the Gain when i substitude the 60 Ohm resistor with a Diode.
