MPP
Here is one channel.
What i would really like to build is the circuit you can download here. If we count a folded cascode as a one stage amplifier this can work. I have done the folded cascodes referenced to the constant current sources. That can be substituted with fixed bias.
The circuit may have some bugs but it is a starting point.
  • MPP Transimpedance.pdf
You can be sure this works fine.
The output current of the OP may not be high enough to compensate for offset
(remember Vled is a weak function of current). R15 should be zero.
Perhaps a non inverting servo is necessary here?
You may want to connect R16 to output VF3.
P3 and P4 are not required.
R4,C5 and R5 ,C* are also not required in my opinion.
