Terms:
Non-credit card PAYPAL accepted. Cost + Shipping
For sale:
3 original LEACH amp boards - fully populated and working (does not include TO-3 output transistors - but does include TO-3 sockets) ONly issue is one of the input pads has come loose because of resoldering. $20 each
2 ASCENDANT AUDIO ATLAS 15 inch subs. NEW in the box unused. $100 each
2 - Original NHT 1259- purchased from Ken Kantor. ONe is unused the other around 30-40 hours mild use. $100 each
1 - 4 channel KRELL KSA 50 clone. Uses 3 pairs MJl21193/4 per board. 1% metal film resistors. This is force air cooled. Pics seen here:
http://www.diyaudio.com/forums/showthread.php?postid=949974#post949974
120000 UF per rail, 2000VA transformer. Soft start. Only issue is soft start relay sometimes sticks ($5 relay). VERY HEAVY ! like 80 pounds. Asking $300 + shipping.
1 COUSTIC 600SE car audio amp - works fine - some cosmetic damage. $50
1 pair of MURPHYBLASTER OW-1s using Hiquphon OW1 tweeter.
Nice black handmand MDF cabinets. High quality crossover components. $200 pair (price of the tweeters alone)
1 pair WHARFEDALE DIAMOND 8.1 bookshelf speakers in black. like new condition. $75 pair
1 LIGHTNING AUDIO FF150.2 amp. Like new condition. $30
8 - MJl15004 TO-3 ONSEMI transistors. Used in LEACH AMP boards above. $2 each
6 NTE60 (MJ15003) NTE TO-3 transistors, Used in leach amp boards above $2 each
2 MJ15003 ONSEMI TO-3 transistors used in leach amp board above. $2 each
8 SANGAMO TYPE DCM253UO75DC2B capacitors. 75 volts at 25000UF. 3 inch diameter and 4 inches high. Screw terminals. Been sitting on the shelf for several years, seem to hold quiet a charge. $5 each
I am located in Knoxville TN (37916) if you want to estimate shipping or think about picking something up. I am VERY busy. There is a wealth of information on the web concerning most the above, if you are sincerely interested and have specific quetions, then ask. Email : zlast@yahoo.com
For sale:
Murphyblaster MBOW1 parts
OK, the cabinets were damaged. SO I removed the mids, Hiquphon OW-1 tweeters and crossovers. Crossovers are all AXON caps, metal film, large gauge air core. Sell all for $150 + shipping.
Also have a 1/2 HP continuous duty electric motor (new)
CHICAGO ELECTRIC
230/120 volt. wired forf 120 right now.
Model CVK 5617D1140 HP. Safety factor 1, 1725 rpm with slotted 5/8 shaft. ASking $25 + shipping, think I can get it in a flat rate USPS box.
ASLo a BOSTON 700 series gear reducer. Worm drive 15:1 gear reducer with 5/8 inch slotted input and 3/4 inch slotted output shafts.
In great shape- can turn easily by hand. $25 + shipping is a steal
Should fit in a flat rate USPS box for USA.
CHICAGO ELECTRIC
For sale Update
For sale: Prices do not include shipping
(PENDING SALE) 3 original LEACH amp boards - fully populated and working (does not include TO-3 output transistors - but does include TO-3 sockets) ONly issue is one of the input pads has come loose because of resoldering. $20 each
Long throw XBL2 motor - cast aluminum frame - perfect for home theater or doing some body modification to your vehicle. $75 each
2 - Original NHT 1259- purchased from Ken Kantor. ONe is unused the other around 30-40 hours mild use. $75 each
(PENDING SALE)1 - 4 channel KRELL KSA 50 clone. Uses 3 pairs MJl21193/4 per board. 1% metal film resistors. This is force air cooled. Pics seen here:
http://www.diyaudio.com/forums/show...9974#post949974
1 pair of Hiquphon OW-1s tweeter. Hand made and matched to 1% accuracy. Maybe best dome tweeter period. HAve GR Research M130 mids in perfect condition and high quality mid/tweeter (large guage air core inductors, Axon caps) for Murphyblaster MBOW-1s speaker:
http://murphyblaster.com/content.php?f=MBOW1.html
For $125 + shipping you get tweeters, mids and crossovers !
(Tweeters alone are $200 new)
1 pair WHARFEDALE DIAMOND 8.1 bookshelf speakers in black. like new condition. $50 pair
1 LIGHTNING AUDIO FF150.2 amp. Like new condition. $25
(PENDING SALE)6 NTE60 (MJ15003) NTE TO-3 transistors, Used in leach amp boards above $2 each
8 SANGAMO TYPE DCM253UO75DC2B capacitors. 75 volts at 25000UF. 3 inch diameter and 4 inches high. Screw terminals. Been sitting on the shelf for several years, seem to hold quiet a charge. $4 each
(1) AUTOTEK 7600BTS car audio amplifier in perfect condition. 300 watts stereo/900 mono - real old school power $100 + shipping
(2) ADIRE TEMPEST 15 inch subwoofers- dual 8 ohm voice coil, XBL2 motor in great shape. $50 each + shipping
(1) 6 channel LEACH amp - features 1500VA transformer, dual 50 amp rectifiers, 100000UF per rail. Uses 2 ONSEMI MJ15003/4 per output. Works perfectly - basically unused since I built it, can see pics here:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=55936&highlight=
Asking $250 + shipping - hate to let it go
Ascentand
Also, it appears that Ascendant offered a low Q, mid Q and high Q version of those Atlas woofers, do you recall which ones these are?
ALL the same driver - you adjust the "Qts" with a wire or resistor across one set of terminals (I have the original Ascendant data for enclosures and setup)
Free STUFF
Anyone withing driving distance (Knoxville TN)
ONe 9 ft3 vented enclosure tuned to 19 Hz, great EBS enclosure
Dimensions are 16 X 24 X 48 inches - has cutout for 15 inch - TEMPEST fits perfectly. Made from plywood (not finished), braced. Free for whoever wants to lug it off.
One 30 Hz tapped horn - MDF 14 X 17 X 73 inches with an EOSONE 12 inch in it - has tapped metal inserts for driver mounting so you can take driver in and out easily through the mouth. Thats right...FREE.
