What is the most powerful opamp avaliable, not including those $500 dollar ones we're always talking about. I would assume it is some OPA chip, but I have no idea which one.
Would anybody be able to tell me what some of the highest power chipamps are?
What I need to do is make a subwoofer, and none of the chips I have produce enough power, like the 3886, 4766, 4780, opa541, opa549, etc. I need at leat 200-300 watts RMS of power, and since the speaker is 8ohm, bridging is possible and is what I am going to do to get the most power.
Or, if somebody has come up with a good pcb for the lm4651/4652 yet, I would like to try it.
Thank you!
Thank you!
Thanks for the reply. If you have time, would you mind suggesting a good schematic to start with?
And, like I said, any working board for a 4651/2 amp would be appreciated.
Finally, is the das module the same as the bridge/parallel 3886 amp? because I am building one of those right now.
also, I was just wondering, what is the most powerful opa chip like i asked in the first post?
LM12 is not very high-tech these days.
soundNERD, have you totally missed Thomas Madsen's excellent pcb which he sells?
Das Modul is mainly a BPA-200 according to the application note AN-1192 http://www.national.com/an/AN/AN-1192.pdf
http://www.diyaudio.com/forums/showthread.php?s=&threadid=19157&highlight=
Per-Anders,
Sorry to disagree with you (again...), but to me the LM12 is a more advanced design than the other GC chipamps. It has a fully symmetrical output stage. With a gain of 10 or more, it can handle 1uF cap loads. This would be the killer GC amp for 'difficult' full range speakers, with 10A current capability, generous SOA and excellent stability.
Jan Didden
Jan Didden
PMA said:GC = simple-to-do + trust (blind faith ). Nothing more, nothing less.
Indeed, and I think the LM12 is even easier to use. Only 4 pins..
Jan Didden
From what I can see LM3886 is substantially faster and has also a bit lower distortion, less noise.janneman said:Sorry to disagree with you (again...), but to me the LM12 is a more advanced design than the other GC chipamps.
The difference isn't huge and I have never heard LM12 so I'll guess this won't create a big debate.
I think that TI discontinued the LM12.
Anyway, I tested the OPA541AM (TO-3), it has 10A current too.
TI asked $80 for each of these beauties, but it seams that now they are not available.
While it has very good bass, the rest is not up to the standards of sound quality of an LM3886, or LM3875, or LM4780, or even the LM1875.
But it's very good indeed, some people may prefer the "warmer" sound of the OPA541.
I just feel that it doesn't have that magical midband, treble and detail of the National chips.
The LM3886 has "typically" 11.5A current, and it's what I use.
I don't use the LM3875 for a long time...
National Semi makes the LM12CL:
http://www.national.com/pf/LM/LM12CL.html
raidfibre said:National Semi makes the LM12CL:
Sorry for the confusion, yes, National.
Although they don't have samples, they still sell them.
demogorgon said:the first thing that came to my mind would be the combo of the LM4651 and 4652. it's a class D subb amp delivering 170w of power.
just a thought
marius
yep, thats what I thought, but I can't find a decent pcb i can make myself. Anybody have one? 1 layer preferred, but two sided can be done.
- Chip Amps
- Most Powerful Opamp avaliable
