Most Greedy Boy, of them all... or (there is no) DEFiSIT of Papa's Koans
Official Court Jester
Joined 2003
SEF
this one goes in prototype
Joined 2003
probably it will not oscillate , but gate stopper is conditio sine qua non , at least in my head
so , no need to draw it all the time , especially when I forget ..... :rofl:
(so , that was good question!)
rationale for output resistors arrangement is nothing else than THD spectra ( and dynamic behavior of mosfets in output)
it looks best this way
edit: just checked - both gate resistors are included on pcb :)
Joined 2003
btw ....... made sanity (sim) check of 2SK180 based DEFiSIT , made with ACS chips
nada - not big enough (voltage) window between gates of 2SK180 and IRFP9xxx to keep current in sane bracket
same case with SJDP
Sorry to quote a relatively old post, but the "1, 2, SIT3" thread triggered me to ask again.
I have some 2SK180D, that gives Id of around 1.5A at Vgs of -3.2V (Vds=20V), would they be feasible devices for the DEFiSIT. (attached are the measurements of the 2SK180D).
Thanks Mr. Pass and ZM :) . It seems quite possible to find a matching P FET, but I'll need to get familiar with the SPICE circuit first.
I have another question though, if you don't mind. In the "DEF Amp" thread, it describes a way to adjust the Vgs matching through 3 resistors. In the DEFiSIT amp, opto-coupler is used - what is the reason for the change.
