Many mosfet power amplifiers based on 2SJ162/2SK1058 lateral mosfets are made. This one is particularly suitable for home-use, being small, having moderate power with very low distortion:
More info:
Mosfet Power Amplifier
- Max output power: 100W@8ohm, 150W@4ohm
- THD+N (1kHz): < 0.005% (measured!)
- PCB dimensions: 100x60mm
- Input sensitivity: 1.2V rms
- Input impedance: 22kohm
- Bandwidth: 80kHz
- Voltage gain: 27dB
More info:
Mosfet Amplifier
Hi, I am interested in buying kits for this amplifier. Please let me know if they are available and what the price is. I will be using it with a 100V line output transformer and a six channel mixer for our church.
Herman
hermanb3@absamail.co.za
Herman
Available as complete kit or pcb-only, so you can select components yourself. Mosfets/components are also available separately.
- Bandwidth: 80kHz
More info:
Assuming one channel, 100W @ 8 ohm, you need about 48V rail voltage, which is also perfect for the output relay. Minimum transformer VA of 125VA would then be required.What is the recommended rail voltage ? And the transformer VA ?
150VA are commonly available, and 35-0-35 transformer will give you 48V rail, which is about ideal.
More info, including transformer computations for other cases: Mosfet Power Amplifier
Hi djuke!
Where is the PCB and part list?
Otherwise the amplifier is very good!
thenks and cheers !
- Bandwidth: 80kHz
More info:
I calculated the audio amplifier.
With these values of the components to shematics ate amplifier works well or these values are only theoretical?
thank you and cheers!
Great work, I actually use different components and values in the input and VA stage, but using 2N5551/2N5401 is certainly an option.I calculated the audio amplifier.
Please keep me informed when the amp has actually been built and measured with these component values.
Simulation of my amplifier
Hello Donpetru!
Since I see that you have a progam for the simulation of electronics circuits, so please if you are able to create a simulation of my audio amplifier, which I designed for this shematic (Figure 1F).
Big thanks in advance!
Hello Donpetru!
formula 22,
That diagram audio amplifier seems not optimized. For example, there is no point can mount only trim P1 in the input circuit of the audio amplifier. Right is to mount a resistor in series with the trim P1. But so, not 100% good. It's much better to try to let the resistance instead of P1, but that only after having established experimental optimum value of current in the input circuit. Bootstrap capacitor C8 is no current solution. It's old-fashioned, as is diagram audio amplifier. Then, R2 and R9 are too high.
Finally, if you want one audio amplifier diagram worth done, download and analyze all schematics (pdf files) that were posted in this topic or thread:
KIT 0205 - schema, modernizare, constructie amplificator - Comunitatea Tehnium Azi
Nice day.
Nice day.
- Vendor's Bazaar
- Mosfet power amplifier 2SJ162/2SK1058
