I am building a Aleph 5 amp. I purchased 16 IRFP240 mosfets in hope of getting 4 matched up groups of three.
My readings for the Vgs are as follows:
1. 3.68 9. 3.84
2. 3.70 10. 3.85
3. 3.74 11. 3.90
4. 3.80 12. 4.13
5. 3.81 13. 4.21
6. 3.83 14. 4.26
7. 3.83 15. 4.27
8. 3.83 16. 4.27
If I group them as follows :
group A 1-2-3
3.68
3.70
3.74
group B 4-5-6
3.80
3.81
3.83
group C 7-8-9
3.83
3.83
3.84
group D 14-15-16
4.26
4.27
4.27
Should the mosfets be matched up in groups of 3, 6 or 12. ?
Assuming groups of three :
Is it ok to have group D as described or should I buy more mosfets to get even better matching.
I used a 24 volt supply and a 30 ohm 30w resistor to get these readings. No heat sinks and took reading after 6 minutes.
I bought 10 9610's and was able to get a group of four at 4.1 Vgs.
I used a 24 volt supply and 2k resistor. Reading stabilized after 2 minutes.
The 240's did get quite hot but the 9610's hardly warmed up at all. Is this normal?
1. 3.68 9. 3.84
2. 3.70 10. 3.85
3. 3.74 11. 3.90
4. 3.80 12. 4.13
5. 3.81 13. 4.21
6. 3.83 14. 4.26
7. 3.83 15. 4.27
8. 3.83 16. 4.27
group A 1-2-3
3.68
3.70
3.74
group B 4-5-6
3.80
3.81
3.83
group C 7-8-9
3.83
3.83
3.84
group D 14-15-16
4.26
4.27
4.27
