Mosfet Citation 12 build questions
Im building the PASS Citation 12 mosfet amp, I have a few questions first I notice the schematic in the pdf shows the audio output of the amp strapped with a cap .068 and a resistor 10@1w with the resistor to the output then to the cap with the other lead of the cap going to earth. this is sequence is reversed on the component layout on the diagram for the circuit board ? does this matter???
correct placement of trace cuts ?
I am starting the build of the mosfet Citation 12, I seeint 2 trace cuts that have to be made am I correct wth the cuts I have marked in red ?
