MOSFET Amplifier IRFP240/IRFP9240
What is the THD of your design?
can you make a screenshot of the schematic?
On the emitter follower driver stage:
I don't want to run my VAS at 25mA.
But to be honest, i guess i will have to check on that matter again more thouroughly. (wich will take some time...)
PS:
Maybe we should open another thread on emitterfollowers for mosfet outputs, or something like that. Maybe there is already a thread on this, we could join. I feel it might be getting a bit off topic.
According to this simulation, the last thing to do would be to add an emitter follower stage between the VAS and the MOSFETs. Can you explain again why you want to add an emitter follower stage ?
Without it, distorsion will skyrocket..
A vas output impedance is too high to safely drive a vertical mosfet gate.
Only the hitachi 2SJ162/2SK1058 can be drived directly by a vas, and yet,
adding an EF buffer greatly increase their THD figures...
I have done the simulation of the Apex HV23 amp under Tina 7 Texas Instruments.
However, I designed the bias stage using a Vbe multiplier scheme. It shouln't degrade audio performance.
See attached files.
There is one file with DC-servo.
There is one file without DC-servo. I think that DC-servo is mandatory.
The two files are reayy for simulation under Tina 7 Texas Instruments.
Audio results look suprisingly good, from the simulations results.
  • Apex HV23 simulations.zip
See attached files.
I see simulation, thank for your time Steph, and I was expected simillar results. Output devices are IRF520/IRF9520 is that just notification?
I've used vertical MOSFETs IRF520/IRF9520 because those devices were available in Tina 7 Texas Instruments Spice simulator.
In Tina 7 Texas Instruments, the available IRF520/9520 devices are simulated using a Spice Level-3 model. Not a subcircuit. I don't think the non-linearities at low current drain are simulated. I don't think the C_gd dependencies are simulated.
In Tina 7 Texas Instruments, I found no 2SK/2SK lateral MOSFET models.
How to precisely Spice-simulate vertical MOSFETs and lateral MOSFETs, especially what's happening at low drain current (transconductance modulation), especially what's happening in Class-B regime, when the device enters cut-off and also when the device enters conduction ?
If improved vertical MOSFETs models and lateral MOSFETs model do exist, how to use them under Tina 7 Texas Instruments ? Will it be needed to upgrade to Tina 7 full version - not free anymore ?
You can add a hint of subthreshold behaviour by putting a diode in series to source.
Maybe the diode model parameters can be tweaked, for a more accurate emulation of the effect.
any thoughts on this?
PS:
Are there really no parameters in the models, intended for modelling of the subthreshold region?
Here's the Apex circuit in LTSpice (sans protection and clip).
I've tried to stay true to the original schematic. Didn't
attempt to upgrade or second guess the design, all part
designators kept same for easy cross-reference. I did
cheat models, and thats maybe now causing a problem...
I don't know if its my substitution of LTSpice default library
transistors to blame??? But there seems to be a small glitch
in the zero crossing. Like output MOSFETs are underbiased?
I'm not sayin the real Apex circuit misbehaves in that way.
I may just need to plug in more correct/accurate models.
I don't yet have all those 2SA transistor models handy.
Anyways, 1KHz large sinewave performance seemed OK.
Didn't see the point to test more challenging signals while
the output bias in my simulation was obviously not right.
I've tweaked bias pot to either extreme. So thats not it...
For now, its set back to center (250+250).
  • apex.zip
What is the bias current in your simulation?
Very easy to check, to see if really "underbiased".
Maybe the V_th of your models is too high for the original trim pot value.
PS:
with P1B set to 250, the FETs are biased off. (some pA)
I set P1B to 2500 (add a zero), I got something like 0.3A per device. The transient looked fine then.
OK, now running 300mA output bias as Krachkiste suggested...
1KHz sine looks perfect, 22KHz a little ragged, 96KHz awful...
But add 100uF from emitter to emitter as has been previously
suggested, sines clean and crossing nice all the way to 96KHz.
At least in simulation its does, whatever that counts for...
I have not yet checked what effect that cap's pole might
have upon phase margin? The sim so far does not appear to
ring or oscillate with 100uF added cap, but thats not a real
thorough analysis...
The amplifier will burn. Before you do that have on mind that I already do that in the past. The only Mosfet at output stage which will not burn is form 2SK/2SJ audio series but if you look their characteristic carefully they have more common with transistors then with POWER MOSFETS.
Used irfp series for years, I know with poor design the current could run away with clipping but it's not at all hard to get rid of, test should be done at higher frequencies too..
10mA ?! You don't think much of hifi do you.. look at the tranceconductance chart and then tell me why I should stay below ~0.3A in my amplifiers.
Also I vote for simpler vas stage(base&emitter to diff amp?w. emitter resistor lower resistance) and separate emitter follower buffer, and vbe circuit, hell I could'nt even get away without it and I only have one pair of output transistors..
Don't take the 300mA I mentioned too serious. It's a good bias, but I just added a zero to the resistance value as a quick estimation, and ended up with that bias. So use whatever bias you please.
The 100µF don't affect the loop-gain and thus stability.
I simmed the loop gain f_t to 91kHz.
Phase margin is 105°
Gain margin is 28dB
so, looks pretty rugged.
A little overcompensated for my taste, but serves the needs of the application.
I was a little surprised, that the THD for 1kHz@45Vp simulates to a good 90dB while having only 38dB of loop gain at that frequency.
Thumbs up on that! ;)
Disabled Account
Joined 2006
Now that is interesting.
Under what conditions did you observe oscillation?
I didnt make it in time to edit, but all is fine, I forgot to bias the outputs.
Im quite surprised at the performance too, not bad at all, its the high vas current, but with such a high vas current its of limited use putting a EF in there but Ill try and lower the vas current to see what difference it makes.
Loading a differential input pair with resistors is a double waste :
- your open loop gain drops
- the wire that connects to the VAS base only can push fast current into it
- the VAS base only sees a weak short-circuit (the resistor load) when needing to turn-off the VAS
-> as a result the VAS is fast at turn-on, but much slower at turn-off
Loading a differential pair using a current mirror removes all defects :
- the open loop rises
- the wire that connects to the VAS base can push fast current into it
- the wire that connects to the VAS base can act as a short-circuit
-> as a result the VAS is fast both at turn-on and at turn-off
What's also improved when loading with a current mirror, is that in case of need, the full differential pair current is made avaible to the VAS. The VAS can thus operate in Class-AB, for a maximum output current that's far more than twice its own quiescient current.
If you have a differential pair current with total Iq = 3mA, in case of heavy differential input, this will translate into nearly 3mA entering the base of the VAS. If the VAS is equipped with a transistor providing a current gain of 100, one may thus expect an output current of nearly 300mA available to the output devices, being BJT, vertical MOSFETs or lateral MOSFETs.
But wait a minute. How do you define the VAS quiescent current ?
If you are designing an asymetric amp, then this is very easy : you load the VAS by a constant current source, and your VAS Iq gets thus firmy defined, rock-solid.
If you are designing a fully symetric amp like the one we are talking about (Apex H23), then we need to think twice.
There is the US patent number 20040085130 by Sifen Luo (filed 2002) entitled "Simple self-biased cascode amplifier circuit".
In this circuit, everything simplifies down for defining a VAS Iq that's completely independent from the differential pair Iq. And you get the benefits of the cascode for free !
See attached Tina 7 Texas Instruments file, ready for simulation.
With this inexpensive mod, one can really boost the Apex H23 specs. The slew-rate gets ten times better. And THD gets halved. All this with a VAS Iq equal to 5mA. Which means less than 1/2 watt dissipation in the cascode transistor. The VAS input transistor only dissipate 15mW, because of his constant Vce voltage drive equal to 3V.
This revisited Apex HV23 is now a kind of "Non Slewing Amp" arrangement, something Giovanni Stochino presented between 1995 and 1998 in Wireless-World (Electronics World). But Giovanni Stochino arrangement was much more complicated !
Have fun !
  • Apex HV23 with diff.pair current mirror load and self biased VAS cascode.zip
A lot of extra parts, just to "self" bias those cascodes.
Have you considered using a JFET+BJT as a depletion mode compound?
What was your reasoning, that a cascode was needed there anyway?
You also didn't specify some transistors, especially in and around the
cascodes... What model would you expect TINA is using for default?
A lot of extra parts, just to "self" bias those cascodes. Have you considered using a JFET+BJT as a depletion mode compound?
Can you skech a schematic ? Then we'll determine if your proposed VAS is compatible with full symmetry designs and current mirrors. The question is : does your VAS exhibit a rock-solid quiescent current, when fed from a current mirror ?
What was your reasoning, that a cascode was needed there anyway ?
As explained above, the cascode comes from free. The only concern was to load the differential input pair with a current mirror (increased gain and turn-off speed), then determine what kind of VAS was compatible.
You didn't specify some transistors, especially in and around the cascodes... What model would you expect TINA is using for default?
When sketching design ideas, a viable starting point is to use default, regular transistors. Later on, one may specify real-world transistors like less beta, more max Vce voltage and lower cut-off frequency. And see the overall performance degradation it causes. One of the advantages of the cascode, is that it allows you to retain a high beta high speed (but low max Vce) transistor at the input. The input transistor doesn't see the Vce excursion. It works at a nearly 3V constant Vce. For the cascode transistor, you need to select a transistor able to dissipate 1 watts (TO-126 ot TO-202 outline are fine), high max Vce (say 300V), with decent speed (Ft 60 MHz) and decent beta (about 50). We had BF871 (NPN) and BF872 (PNP). Don't know if there are better (and still cheap) substitutes nowadays. See attached datasheets.
  • BF871.pdf
  • BF872.pdf
Disabled Account
Joined 2006
Why would one want to retain high beta low voltage transistors if you can use high beta high voltage, very low noise and low cob devices which are easily obtained and far superior to BC models.
A important parameter for the cascode transistor is high beta so instead you should be using a higher voltage input transistor and a medium to high voltage cascode transistor but with emphises on high beta, preferable a super beta model.
The input transistor will then still be working at a fixed but higher Vce and if you look at the performance youll notice that the circuit performance is quite better this way. BF872 is not a good cascode transistor too low beta.
One can see what the different performances will be by changing the spice parameters on the models and then see the effect it has on the circuit performance, this way you can see what kind of transistors are more suitable for the purpose. Current mirrror transistors should also be of the super beta type.
Could you show schematic as a jpg image or other format that other users not having tina could see, Im interested in seeing this self biased cascoded.
Wahab is spot on regarding cob.
