I think that this amplifier still needs some work.
I suggest that you take the power resistors off the Drains
of Q8 and Q9 and put them on the Sources, where they will
do some good.
I also suggest that you think about regulating the voltage
feeding R9 and R10 so as to stabilize the bias better, and
I think you could consider a cap to ground after R15 so as
to better filter the - rail to the front end.
do some good.
