Mosfet AMP 200W very simple
I have this circuit that I found in a forum in Spanish and already many users have made it with very good results.
i wanted to know what modifications there would be necessary to do in order that it could work to +/-65v???
Thanks!!!
  • Amp Mosfet 250w.pdf
Joined 2014
Thank you Jon!...i will tray to do!
Zobel circuit looks funny, 10 Ohm resistor with 68pF cap?
The capacitor should be more like 100nF...
Also, I would put a cap (1uF ?) in the input, so it's not DC coupled.
820 k resistor in sequence with BIAS trimpot also looks weird.
820 k ??? More like 8k or 800 Ohm...
Overall I wouldn't trust this design. Too many errors/mistakes already...
Founder of XSA-Labs
Joined 2012
We live on the edge :)
I think mostly it's because we build amps, not complete amp systems. We move on from one amp to next. If you settle on one you want to use in a permanent (a real case) setup then protection is good. Most 50w amp don't need protection as speakers can take full rail fault for a moment if rated appropriately.
