Morel Supreme 110mm tweeters
Morel Supreme tweeters, 110mm face plate. Used for testing for about 20 minutes total. Never mounted. I do not have the datasheet or the original packaging, but they will be packaged securely. I have shipped other Morel dome tweeters without issue.
Morel's flagship 28mm soft dome treble, with Improved Dispersion Recess (IDR) design faceplate, large underhung Hexatech aluminium voice coil, Neodymium flat pancake design magnet system and sturdy gold plated terminals.
$240+shipping
Technical Data:
Faceplate Diameter: 110mm
Sensitivity (2.83v/1m): 91.5dB
Nominal impedance: 8 ohm
Frequency range: 1.4-22kHz
Free air resonance: 680kHz
DC resistance (Re): 5.2 ohm
Voice coil inductance (Le): 0.09mH
Effective piston area (Sd): 6.0cm²
Moving Mass (Md): 0.44g
Voice coil diameter: 28mm
Nominal power handling: 220w
Physical Sizes:
Faceplate diameter: 110mm
Overall depth (front of faceplate to rear of chamber): 40mm
Faceplate thickness: 3mm
Fixing holes: 6 x 3.7mm diameter on 100mm PCD
Cutout diameter: 76mm
