It this works, then hats off to the scripters who have worked their magic for it to autorepair
IT WORKS!!!
I have no clue whatsoever as to why I got errors... but I tell you what, I'm ejecting the SD card now and making an image backup of it right now!
Don't want to go through that 3 hours again <lol>
Another donation on it's way Tim
I'm totally agree with Phil on this case... no need to touch the swap, and i think, in certain case (with DSD, localUI and other options in same time), you can need more memory...
Why touch the swap file and not configure it (size and usability)
for the percent of use, like Phil wrote, just change this parameter (or create it) inside /etc/sysctl.conf
for the size of the swap file you can refer to this :
Increase size of existing swap file - Raspberry Pi Forums
Hi HeeBoo,
A quick run of "free -h" on a few of my Pis including the one thats attached to Pi Touchscreen:
Headless: ~ 60 - 80M used
PiTouch: ~ 140 - 160M used
I was playing DSD128 on one of the Pi3's and 83M used.
I just don't see a case yet for having a swap file.
-Tim
Hi HeeBoo,
-Tim
In which case, have a small one to help with the build on low memory kit and disable it at the end of the build.
It's always possible that users install other stuff on their moode players which ups the runtime memory usage, even if only temporarily.
Phil
Hi HeeBoo,
-Tim
Ok,
I don't want argue about this, so for the installation process, you can put this step at the end, maybe this can help the process.
But also i don't understand why suppress it when we just can deactivate it.
Like Phil wrote, if we need it, it's not easy to step backward.
Cheers
I got my install working last night and it was working fine, for a while. However whilst updating sources it crashed and then became non-functional. It now just boots up to either no display or a garbled display.
I backed up the image after I built it so I will flash it back to a microsd card again tonight and see if it is a persistent issue. Otherwise I will try building it again.
I tried my old backup several times tonight and every time I set up the local display Moode becomes unusable. Prior to enabling local display it is working fine.
I therefore built a brand new version of Moode and I get the same result with it crashing on boot.
Not sure what the problem is but it is too late tonight to keep going. Will try again tomorrow.
Phil
Ok,
Cheers
Good points. I'll run a few builds with the swap feature left on and see how things look.
-Tim
Did you verify that the build completed successfully?
Post the output from the mosbrief command.
-Tim
I completed the 4.0 build. Went fine except I was thinking it was like the beta and would write to the external card reader. No problem it works fine.
As for the sound quality, in my system 3.8.4 with RT kernel still sounds a bit better lower noise floor and better ambience. My two cents,
Thanks,
Thanks,
I have successfully installed the latest moode 4.0 build.
In trying to mount my synology ds415+ NAS via NFS, I get:
'mount.nfs: requested NFS version or transport protocol is not supported'
I have tried adding vers=4 to the mount options but that throws a mount error.
DiskStation Manager - Knowledge Base | Synology Inc.
I've unchecked the 'enable NFSv4 support' (in NAS NFS setup), but hit the same problem. The shared folder (not encrypted) has been configured for moode r/w access, squash (map users to admin | no mapping - I tried both), asynch, security=sys.
moodelog tail:
20180202 193321 worker: Job sourcecfg
20180202 193321 wrk_sourcemount(): Mount error: (mount.nfs: requested NFS version or transport protocol is not supported)
Any help appreciated!
moodelog tail:
Installation
Hi Theo,
bin neu im Thema Raspberry und hab momentan Volumio laufen.
Würde gerne Moode ausprobieren, weiß aber nicht wie ich die aktuelle Version installiert bekomme. Vielleicht kannst du mir ja helfen?!?
Gruß
André
Hello Tim,
I just 4.0 installed and everything went through perfectly.
I also included my Cirrus Logic Audio Card right now.
And it works fine too.
Now I have to hear something first.
ciao
Theo
Hi Theo,
Gruß
André
I FINALLY got MoOde installed and everything seems to be working perfectly.
I did the install over ethernet.
Now, my corcern:
I now want to move my Pi+Moode into another room in the house that does not have ethernet. Using Moode UI - I went to Network Setting and updated the SSID + Password. Now, its asking me to reboot before these settings take place.
I'm about to reboot, but how will I know what my IP address is going to be once I reboot? I have a monitor plugged in with the Pi - is that going to show me the IP address?
Additionally, when I unplug the Pi to move it into another room, can I just simply unplug and plug it in the other room - in other words, am I supposed to follow some shutdown protocol so as not to negatively impact the Moode+Pi?
Now, my corcern:
moodelog tail:
I have installed 4.0 via the the two step process described on MoOdeaudio.org support. I had no issue mounting music folder on my Synology DS415play. Since we have nearly identical gear if you want to send me a PM would be happy to see if I can help.
Hi Theo,
Gruß
André
Hi Andre
Welcome here.
Please post only in English.
It is one of our forum rules
diyAudio Rules
George
@André
look here:http://www.diyaudio.com/forums/pc-based/271811-moode-audio-player-raspberry-pi-1302.html#post5325432
And just log in via SSH and run mosbrief until it says "END".
ciao
Theo
@André
ciao
Theo
Hi from Athens! Great work Tim, thank you very much!
Can someone please report if last.fm scrobbling is working with version 4? I had no problem with 4b12.
Yes, works fine. I'm using it right now
MoodeAudio’s Music Profile — Users at Last.fm
-Tim
Now, my corcern:
It's always preferable to use shutdown from the Menu.
-Tim
Hello Tim,
ciao
Theo
@tovow, could I ask how you got the Cirrus Logic Audio Card working?
I have the older Wolfson version and would really like to get it working with MoOde 4.0
- PC Based
- Moode Audio Player for Raspberry Pi
