Yes, I used a choke too, although didnt try the tuned choke approach as mentioned by yeo. My PT is the same as Pete and i run it through schottkys ($2) --> 8uF oil caps --> 30H/40ma Hammond choke --> 47uf Solen
I am using AC filaments, with two equal resistors (50R) between the ends and tapping a 0.1uf cap to ground from the center of the two resistors. The whole thing is DEAD silent for 93db speakers.
Praveen
Praveen
-> Praveen, Peter
Thanks for your reply. I'll probably order PSU filter choke L=12H R=350Ω I=50 mA, 2 plate chokes L=75H R=1000Ω I=20mA and power transformer U2=250V/200mA, U1=6.3V/2A from local producer http://www.ogonowski.eu .
I've built my GG for Monica but I get plenty of noise coming out. With only heaters and no B+, the sound is fine (like no GG), as soon as I turn on B+, the noise comes out, left channel more than right, swapping tubes left and right doesn't help. Currently using Amperex, maybe too microphonic? Power is CRCRCRCRC, DC filaments, 120H plate chokes. Would a PSU choke help? Could be my layout? can someone who has done it sucessfully post a pict of the underchaasis for me to have a look?
- Digital Source
- Monica 2 and the grounded grid
