badman said:
No trifoil pattern on these?
No. They may benefit from something similar, but unlike the 126/127 where Mark McKenzie pointed out where to treat, i haven't yet figured out how to ferret this info out of my measures yet.
dave
Re: heard some P10 drivers at VSAC
* microFonken, actually
as has been mentioned before, with stereo woofers folded in, these can be quite more than just a nearfield /computer monitor rig.
badman said:Fonken and a 'lil ff85k minifonkenwhateveryoucallthisvariant.*
Nice 'lil fullrange setups. Can't say how much his treatment did, but they sure did sound like very good small/tiny speakers
µFonken (microFonken) ... prefixes having to do with size are all "borrowed" from the metric system, with the base unit beig a Fonken.
The Bamboo Fonkens ended up going home with Goerge Wright
dave
badman said:and a 'lil ff85k minifonkenwhateveryoucallthisvariant.
dave
Re: Re: heard some P10 drivers at VSAC
At one point during experiments with the µFonken + Woof and the Beringer DCX2496 measured in room +/- 2dB from 25 Hz to the limit of the measuring kit.
And i've just pulled out a proto PLLXO that looks like it might have promise. The goal will be to have passive, PLL, and active XOs for this diminuative cutie.
dave
chrisb said:as has been mentioned before, with stereo woofers folded in, these can be quite more than just a nearfield /computer monitor rig.
dave
badman said:Diminuitive indeed!
Probably worth introducing a little tilt in the baffle, since the FRs will be mounted so low.
We'll likely build that into the base. They will be top-heavy & prone to tipping outherwise.
dave
- Full Range
- Mods for FF85k
