With the volume pot turned down almost all the way, just enough to hear, and with the power on, the signal does not sound distorted.
I hope that I made it clear that the signal was only distorted with low voltages connected to the opamp supply (1.5V and 3V, also from batteries), and was completely silent with a higher voltage battery (9V), as if the opamp was dragging the signal down.
So you are saying it works..but with 9V or more it shuts down?
Yup, when unpowered it works, as the voltage is increased it becomes more distorted and quieter until becoming silent.
A wiring error is probably causing the op-amp to stick to one supply rail as soon as it switches on, thus shorting the signal. Check for solder bridges or wrong resistor values. Measure the DC conditions and post the results here.
LOL,
you got to admit its interesting..Hopefully this is already checked..
M. Gregg
You remove R2 and R6?
They are soldered onto the PCB, shorting them seems to make no difference to the way the circuit behaves.
Is C3/C6 the right way around?
Just triple checked and they are the right way around.
Internal compensation for unity gain?
Output short protection cutting in?
I'm not sure how to check for these, however I don't think the output is shorted, as the volume of the signal is not massively reduced compared to being plugged straight in.
Thanks, Matt
Can someone confirm that the opamp is in the wrong direction in this picture, according to the supplied schematic?
Low-Noise Stereo Preamp Kit : TR Kits : Maplin Electronics
And yes the picture and schematic pic are different.
Normaly the electrolytics are marked + on the board...the board should be correct..looking at the picture on the schematic makes me think check/ trace the board and make sure it matches the schematic..
Yawn..Laters
M. Gregg
Yawn..Laters
M. Gregg
- Analog Line Level
- Modifying Maplin preamp kit
