I have not been able to find any information about using the the 12ax7 heaters as a bias resistor for the output tubes.
I need help to find a way to bias the op tubes.
Plate dissipation for all tubes comes to:
Diss/plate current
V5. 8.2 / 22.7
V4. 14.3 / 40.4
V10. 15.1 / 42.5
V9. 12.3 / 34.6
I would like to make some adjustments as i think the unbalanced tubes are causing some hum. I can't think of a way to bias this part of the circuit without messing up the rest.
Question 11.)
How do I bias a free dc cathode biased 6v6 output tube?
Diss/plate current
V5. 8.2 / 22.7
V4. 14.3 / 40.4
V10. 15.1 / 42.5
V9. 12.3 / 34.6
Question 11.)
It's just arithmetic.
Your schematic has 24volts written on it (under the cathode of each 6v6).
Two 12.6v filaments in series give 25.2 volts - near enough.
Those filaments draw 150mA.
They can be replaced in the 6v6 cathode circuits by a cathode resistor and a bypass capacitor.
I suggest you separate each channel if you are doing this so you estimate 150/2=75mA per channel.
Ohms law says v=I*R, so R=V/I
The resistor you want from the 6v6 cathodes to ground on each channel is
25/.075 = 333 ohms.
25/.075 = 333 ohms.
If I remove the 12ax7s from the 6v6 cathode circuit and replace them with a bias resistor and cap I would lose the dc that is powering the 12ax7s. Then I would have to power the 12ax7 heaters by running another 6.3v ac line from the ip transformer. If I do this wouldn't there be too much current draw from the ip transformer secondary?
Ok... I have been studying a schematic of another amp(Harmon Karden A500) that uses the same cathode preamp dc heater trick(Free DC). This amp has a 100ohm pot between each push pull cathode.
http://shermanr.web.prw.net/A500 Version 2_02.jpg
Would this work for my Bell 3030?
The only difference between the A500 and the bell is the op tube types and a hum ballance pot.
Would I need to ground the grid 270k grid resistors through a connection with the bias pots as is shown on the A500 scheme?
- Live Sound
- Instruments and Amps
- Modify Bell 3030 into a stereo guitar amp project
