hi,
i had posted similar at last time with only two pair transistor modified symasym amp. this time i had tested four pair output transistors 2sc5200/2sa1943.
i just need to know is this correct way to adding four pair of transistor in this amp?
i have tested but to me its woking fine. should i drive it this way?
i have posted the modified design virsion only at output driver.
pls need sugestion on this amp.
thank you
michael
thank you
michael
space2000 said:oh no,....no one to help me......
pls.....pls....pls.......................
Ask Mike Bittner directly he would be able to help you. Have you tried?
