Model Paint Tool - Painting new spice models
I just had a go at downloading Dmitry's paint kit and painted a model for a 3b7 using the datasheet as a model.
It is very easy to get straight into the right ball park but deceptively difficult to decide on the best parameters for a good plot.
For a 3b7 (I couldn't find a spice model here or elsewhere online) I have come up with
MU 19.53
KG1 1885
KP 664.85
KVB 234.06
VCT -0.6372
EX 1.194
This looks like a good fit between 0 and -6v grid lines but diverges at +2v and -8v
Can someone with more experience of painting curves cast an eye on this and suggest strategies for improving this or is this attempt typical of what is achievable?
kind regards
Marek
I just had a go at downloading Dimitri's paint kit and painted a model for a 3b7 using the datasheet as a model.
MU 19.53
KG1 1885
KP 664.85
KVB 234.06
VCT -0.6372
EX 1.194
kind regards
Marek
Where can I download the Paint Kit ?
Disabled Account
Joined 2013
Very close to mine. I usually adjust Mu so that the lowest and highest curve is mostly coincides with data curve. Adjust Ex for interspacing between plots, KG1 for angle, these 3 are mostly used to make the curve fit, I get the following:
Code:
**** 3B7 ******************************************
* Created on 07/12/2018 05:08 using paint_kit.jar 3.0
* [url=http://www.dmitrynizh.com/tubeparams_image.htm]Model Paint Tools: Trace Tube Parameters over Plate Curves, Interactively[/url]
* Plate Curves image file: 3b7.png
* Data source link:
.SUBCKT TRIODE_3B7 1 2 3 ; Plate Grid Cathode
+ PARAMS: CCG=1.4P  CGP=2.6P CCP=1.8P RGI=2000
+ MU=20.8 KG1=3037.2 KP=370.8 KVB=210 VCT=0 EX=1.37
* Vp_MAX=300 Ip_MAX=15 Vg_step=1 Vg_start=2 Vg_count=11
* Rp=4000 Vg_ac=55 P_max=2.7 Vg_qui=-48 Vp_qui=300
* X_MIN=142 Y_MIN=51 X_SIZE=575 Y_SIZE=575 FSZ_X=1295 FSZ_Y=735 XYGrid=false
* showLoadLine=n showIp=y isDHT=n isPP=n isAsymPP=n showDissipLimit=y
* showIg1=n gridLevel2=n isInputSnapped=n
* XYProjections=n harmonicPlot=n harmonics=y
E1 7 0 VALUE={V(1,3)/KP*LOG(1+EXP(KP*(1/MU+(VCT+V(2,3))/SQRT(KVB+V(1,3)*V(1,3)))))}
RE1 7 0 1G  ; TO AVOID FLOATING NODES
G1 1 3 VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG1}
RCP 1 3 1G   ; TO AVOID FLOATING NODES
C1 2 3 {CCG} ; CATHODE-GRID
C2 2 1 {CGP} ; GRID=PLATE
C3 1 3 {CCP} ; CATHODE-PLATE
D3 5 3 DX ; POSITIVE GRID CURRENT
R1 2 5 {RGI} ; POSITIVE GRID CURRENT
.MODEL DX D(IS=1N RS=1 CJO=10PF TT=1N)
.ENDS
