I gotta run and get a new camera cord later so i can post a pic..
Heres what i have on the Sg3525 now do theese voltages apper corret or is there an issue
Pin 1:2.13
Pin 2:5.14
Pin 3:0.00
Pin 4:1.08
Pin 5:1.80
Pin 6:3.80
Pin 7:1.82
Pin 8:0.47
Pin 9:6.00
Pin 10:0.00
Pin 11:0.00
Pin 12:0.00
Pin 13:13.13
Pin 14:0.00
Pin 15:0.00
Pin 16:5.14
Heres what i get on the MIC4424
Pin 1:0.00
Pin 2:0.00
Pin 3:0.00
Pin 4:0.00
Pin 5:0.00
Pin 6:0.00
Pin 7:13.12
Pin 8:0.00
Im not sure if its the right driver ic or not..
Heres what i get
Pin 11 of the Sg3525 would connect to PIn 4 of the driver IC
Pin 14 would connect to PIN 2
Pin 3 of the Driver IC would be connected to ground
Pin 8 of the Driver IC would connect to the Gate Leg of the Power supply fets
Pin 3 of the Driver IC would connect to the source leg of the power supply fets
The drain Leg of the Fet would connect to the emitter of an 2N4403
Does this make sense and does it apper that thats the correct driver IC and do the voltages apper to be right or is there something wrong ?
Pin 1:2.13
Pin 2:5.14
Pin 3:0.00
Pin 4:1.08
Pin 5:1.80
Pin 6:3.80
Pin 7:1.82
Pin 8:0.47
Pin 9:6.00
Pin 10:0.00
Pin 11:0.00
Pin 12:0.00
Pin 13:13.13
Pin 14:0.00
Pin 15:0.00
Pin 16:5.14
Pin 1:0.00
Pin 2:0.00
Pin 3:0.00
Pin 4:0.00
Pin 5:0.00
Pin 6:0.00
Pin 7:13.12
Pin 8:0.00
Heres what i get
Pin 8 isn't high enough. It should be near 5v. This is the soft-start terminal. An internal constant-current source charges an external capacitor. The most likely problems are a leaky cap, a defective CCS inside the IC or possibly an external component holding it down.
Pin 4 also is a bit higher than normal but that may be because the output is shut down.
- General Interest
- Car Audio
- MMATS D2000.2
