One step clouser, I get 191 cm high and 23 cm wide, with a total volume of 89 L..... dose it look right to you?
Is it possible to find the actual length and diameter of the port, or shall I just use the scale drawing.
Thanks GM,
It's a 11kg field coil and it sound soooo sweet. I have been making progress, still no there yet but closer
You're welcome!
Cool! Wish I could afford to have field coil drivers again, but the dramatically rising cost of healthcare will probably keep it a 'pipe dream'.
GM
Thank a lot for your help.
Again, you're welcome!
Please post back what you actually built and how it performed. Can't have too much 'hands on' experience published.
GM
Hi GM,
As I learn more about the program I found that a vented box will provide the same result but with a lower volume.....So I need to figure out what I want and the start the negotiations with the wife.
Well field coil is not a quality mark in it self, actually I have seen some bad designs. Low power consumptions is usual one of the problem this means that the steel is not saturated, it needs a good amount of power to do that and it generates a good deal of heat.
Only if you are willing to pay 400-500% more to get the last wow factor you should look to field coils.
Sure I can keep you posted on what I decide and on the result.
Take care
Take care
- Full Range
- ML TL gone missing
