http://www.diyaudio.com/forums/soli...-audio-power-output-stages-3.html#post2014823
Be careful witn MJE340/350 replacements, they may be substantially different from the old/slow Motorolas, actually better but troublesome.
These thoughts I had also by post #14. I will see the statement of Magnatec. From the good old "2N3055" e. g., still not out of production, there are various versions between 500 KHz and 4 MHz ft. I cannot rule out, whether it is also is by the MJE340/350 since Magnatec this one offer.
MJE340 and MJE350 now available from Magnatec, as I read about this offer from rs components:
Magnatec | Semiconductors | Discretes | Bipolar Transistors | NPN Power |MJE340
Magnatec | Semiconductors | Discretes | Bipolar Transistors | PNP Power |MJE350
But I don't find their own datasheets neither there nor on the own site of Magnatec , only this one from ST in short form version. I will ask Magnatec about the reason.
In general, Magnatec offer a wide range of fine solid state components for audio, both own producs and such from some jap. manufacturers like Sanyo, Sanken, JRC and Samsung - go to
http://www.semelab.com/pdf/acc.pdf
but there I don't find the MJE340/MJE350
This isn't true, as it turned out by an order there. The brand was SGS-Thomson (ST) instead Magnatec. Magnatec is both distributor and manufacturer. RS components is not able to distinguish it clearly by all products.
So I will clarify by phone in the future before ordering.
BTW the BD135 e. g. is labeled with the Magnatec logo:
Magnatec | Semiconductors | Discretes | Bipolar Transistors | NPN Power Up to 3.99A |BD135
Just to throw a spanner in the works
I'm just looking at Tits Or for those of sensitive disposition - Towers International Transistor Selector...
Apparently Motorola MJE340 ft is 10Mhz & the compliment MJE350 is 4Mhz, these are minimum ft values though.
I thought On Semi was the new name for Motorola, i could be mistaken though..
You mean that if i rub a Ford Capri hard enough there might be a DB6 underneith ?
Not exactly
You are as bad as the dearly departed Lumba lol.
Welcome to rswww.com are seliing MJE350's for about 10p each.
They are selling off the last of an obsolete batch.
no, at best, a beetle or a trabant, more generaly, a bicycle..
Option to High Voltage Medium (Video) and High Power Devices for Output and VAS Stage
in this case this thread could be of interest:
http://www.diyaudio.com/forums/soli...wer-devices-output-vas-stage.html#post2239333
- MJE 340 / MJE 350 (MJE340/MJE350) and BD159 - GBP (Transit frequency fT) unknown?
