Konnichiwa,
You might want to try to build up something based around diamon transistor structures. In that case you have an exceptional I/V converter or buffer. J-Fet frontends can be used as well as adding a J-Fet buffer to the negative input to achieve high input impedances on both inputs for other circuits.
Sayonara
Mr Evil said:The idea is to create a discrete op-amp small enough to directly replace a DIP8 IC op-amp, ideally surpassing the performance of one of similar cost
Sayonara
Inspired by Mr Evil's work, this is my own attempt :
http://www.diyaudio.com/forums/showthread.php?s=&threadid=120445
Patrick
Patrick
