oops...
but foam core doesn't soften reflection either, especially mounted on the wood baffle.
I mounted the drivers, and closed it off.
I didn't have time, nor could play loudly, but had to give it a 30 sec tryout... Happy to report no boxiness to the sound this time.
Might have been because I have been a lot more careful this time assembling the whole thing, which took me a lot more time than I thought it would.
foam vs wood resonance
Could we get nearfield measurements for the same dimensions & drivers built from wood and foamcore from people who have built them and have a measuring mic?
I've noticed an interesting thing, not sure if it was already mentioned here or in the foamcore thread: when prototyping, I've built a tqwt with the same internal dimensions from 1 cm thick XPS foam (no paper backing, but stiffer than the cheap foamcore, cannot be bent) and then from birch plywood, and the XPS seemed to be tuned almost 11 Hz lower! Port measurements of the two and a hornresp simulation are attached. (hornresp is even higher perhaps because I don't properly compensate for additional space added by folding and a bit different in upper bass because I can't approximate the effect of stuffing well enough)
I double checked the dimensions, and the XPS one was actually internally a bit smaller because it had bracing, while the wooden one did not. Other than that, no difference between the two except maybe stuffing, I used something like polyfill and the amount and location looked the same between the two, but I did not measure or weight it. I have since gotten similar result with a different tqwt which was tuned to about 58 Hz and the difference was only about 6 Hz, but was present.
So, the idea here is - what if this is happening with the Karlsonators as well and while copious damping helps, another reason might be that the wooden ones actually are tuned a bit higher and for that reason have some resonance in the midbass, which makes them sound boxy. In that case a simple rescale that tunes them a few Hz lower might help.
oops...
Looking good!
The duallies sure are nice, wait to you hear a pair with the Faital Pro 3FE25 drivers, it's a different league
What dimensions and driver did you use here? I'm considering a small wood set of K's and since I have both .40 and .53 scale on hand in black elmer's foamcore, it would be pretty easy to test both I suppose, but it'll be a long while yet before I can afford to have a set built or build a set myself.
I should have been more clear, the measurement is not a Karlsonator, rather a tqwt similar to a Cyburgs Pipe or something like that, using a TC9FD. So I'm interested to see whether this happens with a Karlsonator too or not. But I can't really measure it because a) I only have the XPS version and it might be different with the dollar store foamcore that most people use b) my 0.40x Karlsonator uses Visaton FRS8 which again almost nobody uses.
The reason I'm posting here is because if it was happening with the Karlsonators, it might explain part of the boxiness that people get with wood.
Thanks for sharing your observation Vozka. XPS might be showing lower bass reach because of secondary vibrations. I noticed this on a foam core front horn and when I added mass vibration damping, it went away. Also reduced mechanical vibration distortion too.
Usually reflex port tuning is function of volume and port size.
I am quite sure boxiness sound in wood has been solved - must use good absorber like melamine foam in back chamber surround driver as well as around front chamber where possible.
Dual 3FE25-16 Karlsonators powered with 11wrms MoFo single MOSFET amp and Melbourne preamp. Great combo. Really surprised at the synergy of a simple amp and good speakers.
Very Nice XRK!
I´m about to build the "tall" ones i sent a render of earlier, and are wondering about the Slot. What is the benefit to not make it all the way to the top like you did here?
I 3d Printed some fixtures to make sure the angles stays correct during Gluing. Worked like a charm!
That.Is. So. Very. Cool. !!!!!
- Full Range
- Mini Karlsonator (0.53X) with Dual TC9FDs
