Hi, The power connecting wire will go through in the middle of the cases by drilling two holes with diameter 10mm. Thanks
So if I was looking to the side of the case I would be able to see the wire go from the top case to the bottom, correct?
Thanks,
Chevy
Thanks,
Hi Chevy,Yes you are right. The distance between top case and the bottom case is around 20mm.So,if you looking to the side of the case in short distance,you can see the wires. Thanks.
Hi....i can send the chassis by China air post. Arrived in 15 days.TheSeekerr said:Hi,
Is there a cheaper shipping method available? I'm not in any hurry.
$30 to Astralia.Thanks.
