I was just about to suggest the same for a starter.
You can get by without the coil depending a bit on your speakers.
Quite a few built it without the coil but a bit more capacitance.
(You should of course include a fuse on the primary side)
Do a search here in the forums and you´ll find loads of different setups.
That should also give you an idea:
http://www.passdiy.com/gallery-misc.htm
