yes it is
you can do it even without balanced input
enable balanced inputs (as in any Aleph with balanced inputs )
then fed one channel on positive input leg (negative grounded )
other channel fed on negative input leg ( positive input grounded)
of course - output from two hots
The heat-sinks are much smaller and cheaper, plus I like the idea of true mono's ! So is bridging do-able ?
2ch aleph mini (1ch bidge)= around 60-65W dissipation
1 ch aleph30 = 90W dissipation.
but you can run aleph30 on lower rail voltage to drop dissipation and also power.
you will not get more classA power vs dissipation if you bridge 2 aleph mini's.
and aleph mini bridged amps will want to see 16ohm speakers.
- Mini-A Mono-block Is it possible ?
