I use belden cat5 teflon isolated wire...got it really cheap..3 of the 4 tp are teflon and 1 tp is pvc... but that was a one off buy...the shop where i got it has got none left..
but any hookup with solid core is good enough imo..
the coax that has air as dielectric should be ideal..except it is ungainly in use..
I picked up a lot of Teflon insulated wire on ebay for what came out to $0.03 per foot including shipping. The stuff is there all the time. Search for "teflon wire".
I can't say it "sounds" better (I seriously doubt it) but is sure does solder better. Teflon insulation doesn't melt like PVC, so you get good, nice looking solder joints every time.
MR
MR
Teflon insulation has an almost greasy feel to it. It is hard to strip with a regular wire stripper because it takes a lot of force to cut it and you usually end up cutting some of the strands of wire with it, especially the 19 strand stuff. It is hard to cut the insulation cleanly so you end up with little whiskers of teflon attached to the ends of the wires.
If you're going to use a lot of teflon wire, do yourself a big favor and get a thermal stripper. It will cleanly melt through the teflon without damaging the wire underneath. You can pay top dollar for a thermal stripper if you get it from a tool company, or you can look for one on ebay or at a ham fest. I picked mine up for $10 at a flea market.
MR
MR
- Design & Build
- Parts
- Mil spec wire?
