here's an old in-room graph of a "small" 150Hz tractrix given to me by Bruce Edgar loaded with an Eminence Beta8cx with Eminence CD8 (aluminum diaphragm) compression driver and an Eminence 1K6 ("textbook") crossover - there's no highpass - unfortunately I didn't measure it with a highpass/bandpass on the cone driver to see what could be done nor its performance with a 6.5" Audax as the flat foam surround had started to rot on the latter;
Around 100$ would be nice. Sadly, we can have some Beta Three / Elder Audio drivers in Europe through Thomann. But the extremly well horn driver 10LB075-8M is unobtanium : ( I found the most usefull drivers at very obscure places. MAG audio, Sica...
Maybe in the guitar, bass department?
I thought a good horn driver would have low Qts
I fear the very cheap driver have too high distortion
what size is optimal ?
There are some very low Qes guitar speakers with extremly stiff suspension
Just found this!
MCM Audio Select 12" Woofer with Paper Cone and Cloth Surround - 175W RMS at 8ohm | 55-2952 (552952) | MCM Audio Select
Thiele-Small Parameters:
Also:
http://www.mcmelectronics.com/product/MCM-AUDIO-SELECT-55-1220-/55-1220
Specifications::
Power Capacity: 100W/200W RMS/peak
Sensitivity: 98dB (W/M)
Impedance: 8ohm
Re: 6.8ohm
Le: 2.15mH
Frequency response: 26Hz~3KHz
Fs: 26Hz
Qts: 0.30
Qes: 0.34
Qms: 2.33
Vas: 175.88 (liters)
Xmax: 2.25mm
- Resonance Frequency Fs: 38 Hz
- DC Resistance Re: 7.2 ohm
- Mechanical Q Factor Qms: 2.8
- Electrical Q Factor Qes: 0.385
- Total Q Factor Qts: 0.34
- Equivalent Cas air load Vas: 108.0 liters
- Coil Inductance Le: 0.923 mH
- Efficiency Bandwidth Product EBP 98.70
- Voice Coil Over Hang X-max 3.75mm
Also:
Specifications::
Impedance: 8ohm
Re: 6.8ohm
Le: 2.15mH
Fs: 26Hz
Qts: 0.30
Qes: 0.34
Qms: 2.33
Xmax: 2.25mm
re:55-2952 - real parameters:
http://www.diyaudio.com/forums/subwoofers/211646-bang-buck-18-15-subs-2.html#post3067064
dunno who has real horn drivers cheap - I use 12pe32 in a little Karlson - its not cheap
This is my list sofar of suitable 10 inch drivers. In order of 2x Fs/ Qes mass roll off point:
[FONT=Arial, sans-serif]
Beyma 10Mi100/ 712 Hz[/FONT]
[FONT=Arial, sans-serif]B&C 10MD26/ 610 Hz[/FONT]
[FONT=Arial, sans-serif]DAS audio 10B/ 607 Hz [/FONT]
[FONT=Arial, sans-serif]Precison Devices D.107/ 576 Hz[/FONT]
[FONT=Arial, sans-serif]18 Sound 10M600/ 560 Hz
RCF L10/L750YK/ 544 Hz[/FONT]
[FONT=Arial, sans-serif]Beta Three 10LB075-8M/ 538 Hz
[/FONT][FONT=Arial, sans-serif] Ciare PW 256/ 530 Hz[/FONT]
[FONT=Arial, sans-serif]MAG Audio M1021/ 529 Hz
KAPPA-10A PRO/ 520 Hz
B&C 10PLB76/ 505 Hz[/FONT]
[FONT=Arial, sans-serif]18 Sound 10MB600/ 504 Hz[/FONT]
[FONT=Arial, sans-serif]B&C 10FW64/ 504 Hz
Sica 10F2.5CP/ 388 Hz[/FONT]
[FONT=Arial, sans-serif][FONT=Arial, sans-serif]MAG M1040/ 356 Hz
[/FONT] Sica 10E2CS/ 333 Hz [/FONT]
There is no judgement on actual (measured) Qes, x-max, Rms. Availability or price. Although no driver in this list is above +- 220$ from where my shopping cart is placed.
Some other diameter examples of good or famous horn drivers.
[FONT=Arial, sans-serif]6 inch B&C 6MDN44/ 634 Hz[/FONT]
[FONT=Arial, sans-serif]8 inch B&C 8PE21/ 734 Hz [/FONT]
[FONT=Arial, sans-serif]12 inch EVM 12L/ 449 Hz [/FONT][FONT=Arial, sans-serif]
15 inch Klipsch KE33/ 168 Hz
15 inch EVM 15L/ 344 Hz
15 Inch Vitavox AK 151/ 333 Hz
[/FONT]
[/FONT]
fwiw the ev evm15l and and 15b have been dr edgar's midbass of choice for over a decade in his titan 80 hertz horns. good to 500 hertz on the top side.
That's in a folded horn - 15l goes to 3k in my 70 Hz hypex straight horn
- Midbass horn
