No, not integrated. Just use the softstart to drive the push button and LED in the button.
The very small PSU is to match the brightness of the leds in the front panel(selector switch) to the led in the power switch.
The case was chosen to match the one of the power amp.
I built a Hiraga 20Watt Class A. So this baby will drive that amp.
Using horn loudspeakers?
No, electrostats. Very, very transparent sound.
They are kind of home made: Final 400 panels with adapted PIO PSU's.
And a subwoofer for the low frequencies. That sub is why I probably will put two diamond buffers in from Sjostrom. I do not want to lose too much signal.
Looking nice in those boxes as a combo. The coupling capacitors are missing so its more direct sound. Could be telling more about the source & system. Taking it up to 200mA with some small sinks could give more fleshy tone. The four 220R could be exchanged on type preference. Some use Z-foils or wire-wound Miniohms as ref neutral components there. But expensive. Let the lytics completely form out with some playing hours as Stajo said nonetheless.
- Mezmerize DCB1 Building Thread
