You could use 6-10dB of extra line gain for a 300mV phono if your listening space is big but that depends on listening habits and record cuts also. You could make a test with a volume pot only, which is unity gain, before deciding.
Also read: What is Gain Structure?
Mine is 300mV consumer output level standard. To cover all those different sources in good dynamic even with some quiet records and 89dB speakers better use a times two gain preamp (6dB) or just put a x2 gain circuit/transformer at the output of the phono inside its box and use a unity gain line preamp like the Mez.
Can I run an op amp off the existing 10v rails on the mezmarise board. opa 1692 650 µA per Channel. Using the input relays to have a gain position on the input rotary, for each input. Thus accommodating the rare occasion my system requires more gain without permanently introducing another stage.
Wonderfully transparent pre amp with drive, Many thanks.
Any thoughts gratefully received,
Kind regards Nick.
Kind regards Nick.
- The diyAudio Store
- Mezmerize B1 Buffer Preamp
