Attractive though the M2 is, if I was going for an active speaker of this size or less, I'd look at an established kit and proceed by replacing the crossover with an active version. That gives an easy set of steps and you can judge the results as you go along.
This would be a good candidate using modern drivers
SB Acoustics :: Eka
SB Acoustics :: Eka
Has anyone here watched the film Pi? If you have then you may perhaps understand my singlar purpose and this cultural reference...
"I'll restate my assumptions" - MTM driver layout with a front port, HxWxD of 500x180x375 and an active crossover.
I'm not being rude, just bloody minded
SB Acoustics :: Elok
Well most people here will tell you I'm very bloody minded.
Simple fact is I'm not going to try to tell you your build for you.
I will point you in the right directions and criticise the wrong ones.
But you have to work it out, you have to choose what your building.
rgds, sreten.
Passive Version Of Meridian's M2 - which Model No ??
I am looking for the passive version of Meridian's M2. Thank you very much for an advice.
1) Tweeter:
ask there:
Contact - GLOCKENKLANG
ask for the tweeter successor of "Acoustic Art MK III"
check out also this threads:
http://www.diyaudio.com/forums/mult...glockenklang-phenol-99db-based-rcf-tw116.html
http://www.diyaudio.com/forums/multi-way/155885-99db-dome-tweeter-without-titanium-without-horn.html
2) Bass-Midrange:
KEF B110 REPLACEMENT SP1003. FALCON F B110 8 ohm. PAIR. MADE IN UK.
Fane International Ltd Loud Speakers
and ebay item No 360623557800
http://www.ebay.com.au/itm/FANE-STUDIO-5FR-LOUDSPEAKER-FULL-RANGE-5-35W-/360623557800
I've decided to try and build a Meridian M2 active speaker clone. I have the cabinet dimensions and the schematic for the crossover but I need to source the drivers. It originally had KEF units, tweeter was either T52A (SP1049) or T52B (SP1072) and bass/mid was a pair of B110 (SP1057). Do I hang around on fleabay trying to find originals or are there modern alternatives (must be available in the UK) that would work?
1) Tweeter:
ask there:
2) Bass-Midrange:
And reading the thread after it coming up again, it's a shame in a way that the OP and others thought that the SP1057 of the B110 was going to be expensive on ebay.. Back in 2012 they were going relatively cheap because people were only interested in the earlier B110s. Today they are about £50 each.
bosedtobosed - you do see amp/cross-over boards sold separately and selling for about £100 the pair on ebay. Obviously not that common..
- Meridian M2 clone - driver recommendations
