V/Div set to 2v and 2uS
Q212 and Q214 look similar:
Q256 and Q216:
and finally Q253. If I press on the driver board the signal on Q253 turns into the same signal seen on Q212/Q214:
So there is definately something wrong or loose on at least one of the driver boards. Also some of the corners of the gate signal seem to be slightly rounded.
Q256 and Q216:
I fixed the driver board on this amp. Turned out one of the 1 ohm resistors had a crack in it. All IRF650/9650 outputs are stable and the amp is able to produce clean audio. I just got my fresh order of IRF3205 fets for the PS and just need to know if the 22ohm gate resistors are a good match?
