ThanksI'm so sorry.I had to goto to hospital for my dad.I'll have it posted within an hour.
I will Perry..if I don't get any other info.I don't have anything on that specific amp but if you post a photo of the driver board, I'll see if I have photos of an amp using the same board.
yes,Im positive.The vertical driver board,right in front of the output fet's.Are you sure about r206 on the board closet to outputs?The numbers aren't even close.You have some pics so I can try to match this up for you?Or some more info.
my board layout is slightly different,your board has more sm components,but the value of r851,and r845 is what I need,can't quite make it out from the pic….thanks. Also what is the model number of the relay behind the speaker output terminal.Thanks for your help.Hope this helps
Thats the exact layout Perry.Is this the board you have?
- General Interest
- Car Audio
- memphis 16-500d
