I admit that I looked at the pic but not very closely. Blowing up that resistor takes a bit of doing. Hopefully you have followed Suresh's advise.Will check that. Btw did you see the pic I posted on the previous page?
It will blow when a positive or negative DC current is inserted into the RCA ground at the input. This could happen during a connection error, or very likely that a balanced line was connected to the single ended input of the Maya. Hopefully there will be no other damage other than Rg!
Hugh
Hugh
Finally ready , big test in my attic will follow . Heavy beast for shure.
Well Done!!!!
Hopefully you will have wonderful music for many years.
Oh my...that has got to be one of the best looking Maya's i ever sawFinally ready , big test in my attic will follow . Heavy beast for shure.
I wonder where that front plate design came from .... missing a couple of handles though....
Messing around...congrats on the build , i am starting my 5th Maya ...gotta love Hugh !
Be the best you can be ... this is the Maya mk4 chassis in all its glory. I have had some practice with this as this is my 5th chassis build on this model, so on each version one gets to update issues and upgrade looks and functionality. This is a "tight" fit on all components but i managed to keep it clean. The latest GK1+Lifeforce build was a bigger challenge and i learned a lot from that. So this seems a walk in the park compared to that.
For now, i have the chassis assembled, absorption feet, handles on, plugs and connectors fitted, LED wiring, toroids mounted and i even managed to fit a Felix Power Conditioner on the AC input ( PCB by FOLSOM). The AC receptacle has 2x -fuses 10A, plus the Felix also has a 10A fuse so quite well protected.
I am now waiting for the modules from Hugh, to make it sing ( for now it only emits a quiet and relaxing sound of silence ) Best one i have heard though
Also going to start working on the input and output cabling , got to search my inventory for what its available. Never know what's in stock.
I leave you with the current build..... gotta love the Man ...always pay tribute !
Cheers to all builders !
Filipe
Filipe
- More Vendors...
- AKSA
- Maya200
