I have to replace the blown fuse of one of my Martin Logan Aerius.
Unfortunately on the fuse body there isn't any indication.
Could anyone provide me with the specification of that fuse (voltage, current, fast/slow) ?
Thanks a lot.
Hi Sandor,
I'm wondering if you still look for the answer.
I don't know the original fuse (us type) you can check with ML support team (or call Dana at ML support).
I have the same problem just recently and I just use the normal fuse with 5A and 240V and its work, but may be this is not the correct fuse.
