Marantz PM-66 similiar to PM-57
Hi there. I am new to this forum and did start a thread regarding a fault on my Marantz PM-57 amplifier but was advised that the PM-66 had the same transformer and I could get some help from this thread. If anyone could help me with the schematic for that amplifier as I am trying to source a replacement transformer and need to know secondary voltages, VA etc. If anybody knew where I could actually get my hands on a replacement transformer I'd be eternally grateful. Many thanks for any help you might be able to give.
Here is the service manual for PM6010 which is the same as PM66 (apart from the output transistors which have been changed)
http://www.eserviceinfo.com/downloadsm/15368/Marantz_PM6010.html
My PM66SE AMP (10 years old) has a problem. While listening via a radio tuner the mute would sometimes cut in and out. It operated OK with a CD player. Then one day I switched on and the amp power lamp would not come on and the amp would not work at all. I found the fuse had gone in the power circuit and changed it and the amp worked again several times playing CD's, but the mute would sometimes cut in with a loud click. Now the fuse has blown again. Any ideas please?
The mute you're referring to is the protection circuit activating, which could be for one of several reasons. The blown fuse would indicate a fair amount of current is being drawn by something within the amp. I'm far from an expert so cant really advise you on what steps to take, but I would probably start by checking for dry solder joints or cracks in the pcb/tracks near the power transistors on the heat sinks. There is a resistor which feeds the protection IC on this amp (R801 if I remember correctly), which runs VERY hot & eventually burns out - it happened on mine, and caused the protection to engage randomly until it died completely. If you look on the schematics you should be able to find it and test with a multimeter if you have one. Although this wouldnt cause the power fuse to blow as far as i know.
Good luck!
Good luck!
Hi there. I posted a message asking where I could source a replacement transformer for my Marantz PM-57 amplifier but didn't get a response. If anyone could help me I'd really appreciate it as it is just sitting there broken and looking very sorry for itself.
Do i need to exactly match the secondary voltages? I don't seem to be able to find anywhere that has suitable transformers.
something wrong with the schematic?
If D701 and D703 are normal silicon diodes (not-Shottky barier diodes), then Q703 (VAS CS) will dissipate above 0,3W just when amp is idle (no input signal). And 2SC2240 is a 0,3W transistor. And when outpit voltage will raise near clipping - twice amount of max power - so it surely die.
Hi, everybody. I've just bought PM-66SE, but there was no manual with it. I've spent a lot of time looking for it over the internet, but in vain. If anybody could send me the user guide it would be great. u-fig@mail.ru Thank you.
Manual
Apparently the circuit is the same as the Marantz PM6010F. You can download the service manual from
Idling current adjustment
Hello again. I have a little problem. My pm66se has a marked difference in loudness between the channels. So I tried to adjust semi-fixed resistors the way it is described in PM6010F service manual. In about 10 minutes after power-on my digital multometer shows 4mV idling current value on the left channel and 5mV on the right, but in the manual it said to be 10+/-2mV after more than 5 min.
If anybody has PM-66SE (74Pm66/15B) manual, please tell me that idling current setting value indicated in "idling current adjustment" section. Thank you.
- Marantz PM66SE
