The best option for muting transistor removal and no noises is to build a relay muting cct
Muting cct
You can run the signal through the relay contacts or drop the signal to gnd.
Brent
Muting cct
Brent
Hi all,
I own a Marantz CD63SE and was just wondering why you are all removing the HDAM buffers?? Do they cause some sort of terrible noise or distortion that i've missed?? After all i'm sure that there must be some reason why Marantz went to so much trouble to develope the HDAM system and include it in this ledgendry cd player??
Leigh
Leigh
rowemeister said:The best option for muting transistor removal and no noises is to build a relay muting cct
Muting cct
Brent
thanks ... which type of relay should i used ?
Just about any dpdt dil reed relay ( or dpst ) will do
http://www.farnell.com/datasheets/35538.pdf
Andy
Muting cct
Brent
rowemeister said:
ermm i think i just connect the signal to ground also can work ? than no need to get a relay
ermm the diagram you show me i see is 7809 regulator mine is 7808 for 5v
rowemeister said:That's what the transistors do!
Brent
thanks i slowly find out i abit blur
Keep pushing my friend.... everything will come out right in the end.
Unfortunately, the answer is neither.
The mechanism in the CD63 is a CDM12 not 4 or 9 and the parts are not compatable.
You should carefully take the mechanism apart, clean it and reassemble.
I have had very few problems with this model.
Andy
Edit - you beat me to it, Brent. I will have to type faster !!
Andy
rowemeister said:Remove mech from cdp.
Slide out the tray (clip to move)
Remove plastic cover, gears and belt
Clean all the parts and re grease
I've never seen a worn gear yet.
Brent
ermm my CD63 have some noisy sound when ejecting put grease already but still have the sound very irritating plan to buy new tray n transport where can find ? thanks
- Digital Source
- Marantz CD63 & CD67 mods list
