6h5c said:
Maybe the only time in my life I can correct Ray: voilà !
My question of the evening, is there any change/improvement that should be applied to the Flea parts list to match better our CDP, or is it already perfect? (yes, I've got it! Thanks the kind Martin!)
Here I go for my Flea, its PSU, 3 regs (+/-12V from Audiocom, 5V from... don't know, Tent Labs or Audiocom... any advice? The separate 5V will be for a later upgrade), and the coax mod. Any help for the choice of Tent Shunt or Audiocom will be nice (for the 5V as it can save shipping if bought with the XO).
Thanks!
Yes, you're right
Apologies, my last french lesson was about 20 years ago...
Concerning the Flea: i'm not very happy with tantalum capacitors. Nowadays electrolytics are available that have lower ESR and they are much cheaper. In the last one I built I used a BG N series at the output (C9) and a ZA at the input (C1). The rest of the components are fine I guess. Maybe if you want you can use Holco's for the resistors .
Regards,
Ray
Regards,
Ray
I have not fitted the Audiocom Superclock 3 yet as I tried a Superclock 2b on the servo. The gains are better than the divide by 2 circuit. The divide circuit is of course much cheaper.
The dedicated clock improved further on the micro details the divide circuit gave, on Diana Kralls - Stop this world @ 2:18 there is distortion in the treble. This detail could not be heard before!!! Eric Clapton Unplugged has benefited the most with finer details appearing more forward and life like, bass resonance has also improved. I will keep this clock on here now and look forward to fitting the SC3 on the dac tomorrow.
Brent
Brent
I have bought some of this on ebay to use in cdp from dac through to the rca. With whats left I may do my amp internals. My interconnect is made of this stuff so it makes sence to use it internally.
Silver wire
Brent
Silver wire
Brent
Hi Brent ,
have a question about clocking /reclocking
want to use the 63 as front-end withr the DDDac via I2S-Bus ,
Servo+Decoder need their own clock ,
but whats with the Microprozessor MN187164 ?
Need the MN also a separate Clock ?
Thanx in advance
Greetings from Germany
Jürgen
Thanx in advance
Jürgen
Hi there..
Well I have cleaned up my 63 a bit today. Mainly cosmetics
I've newer liked my implementation of the servo reclock (it was ugly, looked like a GPS antenna ). More important, the 7474 was fed from a Flea (the one which also is feeding the DAC pin 27, clock supply). I was looking at its Vcc with my o'scope - uggghhh - it was noisy. Then I reverted the servo reclock and the noise was gone. The 7474 was decoupled.
If this is to be done again, it will be done with a separate clock - like Brent's.
avr300 said:Hi there..
I find the 7474 needs its own good low noise reg to get the best out of it. It will impress. But yes the seperate quality clock is superior.
Brent
Alrighty then.
Just received a shipment of various Black Gate Std caps and have installed them in key places. The left overs will be used to make the separate power supplies.
I also ordered a pair of 51ohm Shinkoh resistors which I have connected between the HDAM bypass wires and the outputs.
I turned the player on and it all lit up!!.....as in, it worked, not an Adfinni.
Unfortunately, my wife is watching a recorded show so I can't listen straight away. Good opportunity for the amp to warm up though.......................
(Fingers drumming on desk)
Simon (Oz)
Simon (Oz)
6h5c said:Yes, you're right
Regards,
Ray
I saw you have apllied flea and kwack clock7 in the different cdp, I will not say what the best but I want to know the 'character' , more and less in the each clock, could you explain ?
aquar
Here is a pic of the Super CLock 2b on the servo with one of my own S Power regs.
Brent
Brent
Quite true; but low ESR is not always a Good Thing, especially on the output of active regulators. It's often better to have a nice resistive characteristic... that's what I use tants for (esr of 1-2ohm can be quite useful ocasionally). That said - experimentation with other parts is all part of learning stuff/getting the result you wanti'm not very happy with tantalum capacitors. Nowadays electrolytics are available that have lower ESR
martin clark said:Quite true; but low ESR is not always a Good Thing, especially on the output of active regulators. It's often better to have a nice resistive characteristic... that's what I use tants for (esr of 1-2ohm can be quite useful ocasionally). That said - experimentation with other parts is all part of learning stuff/getting the result you want
Oh guys, now I'm in trouble...
LOL
When picking items like Precision reference low voltage devices you need to read the small print on such a device, too low a esr can cause ripple and voltage drop out.
Brent
Malefoda said:Oh guys, now I'm in trouble...
Yes, i'm afraid he's right Matthieu...
Looks like you're on your own with this one
Which one is it going to be? The tant or the ZA????
Ray
(P.S.: I think both will work fine in the Flea)
aquar said:I saw you have apllied flea and kwack clock7 in the different cdp, I will not say what the best but I want to know the 'character' , more and less in the each clock, could you explain ?
aquar
Hi Aquar,
The character of both clocks is the same IMHO: better soundstage and spacing, more detail, you know, the usual veils being removed. The difference is in how much you get of all this.
First I used this PCB of mine for a while, with the sort of Kwak-clock Tent-psu combo on it. It gives a lot of improvement over the standard clock in the player and it is very low-cost. You can put it together on a piece of Veroboard in minutes. So it makes a good DIY bang-for-the-buck to start with. You can even use it without the (expensive) comparator and use a 22...47n cap to connect the signal to the DAC instead.
The Flea is more expensive but I find it delivers more musical goods. Well worth it, the difference is clearly audible. It's not an oscillator like the Kwak, but an advanced voltage regulator for the Tentlabs XO-module. The XO is very easy to use and fully canned/screened. I don't know how a 'genuine' Kwak-clock 7 sounds, with the symmetrical TL431 supplies, I never tried it. Probably better than my simple DIY PCB, just like the Flea is also better.
For both clocks goes: a separate PSU improves things even more.
Regards,
Ray
martin clark said:But now you see why there is 0R5 between the 7812 and the decoupling cap for the opamp.
Yes, you added some DSR = Discrete Series Resistance
- Digital Source
- Marantz CD63 & CD67 mods list
