I have a Marantz CD10 (CDM4/36) and have sometimes problems, that it soes not read the TOC when inserting a CD.
The turntable motor does not start after inserting the CD. But it is not a turntable motor problem, since the motor works perfectly (under test program conditions). Seems, that the pick-up does not recognize the CD. On the other hand, I do not have any problems with reading CDs, even CD-Rs.
Any suggestions here?
Cheers
Trellis
Cheers
Trellis
tubenut said:dodgy spindle motor?, what happens if you give it a little finger "push start" while laser tries to focus?
What does the display say when the disk does not spin??
If the laser tries to focus but the disk does not spin :-
Laser dirty
laser height adjustment
turntable motor sticking
Check voltage between pin 1 and 4 on the motor board when laser is trying to focus
i had same problem on my cd10...
Hi Trellis,
try to read this post and then write me, i had the same problem on my cd10, and now seems to be solved, or improved...
http://www.diyaudio.com/forums/showthread.php?s=&threadid=66698&highlight=marantz+cd10
good luck
DoctorWho70
Hi Trellis,
good luck
DoctorWho70
- Digital Source
- Marantz CD10 TOC error
