All drivers work fine. Prices do not include shipping.
TWEETERS:
1pr- Philips AD0160-T8- clear mylar-dome with screen. $30 for the pair.
1pr- Polk SL1000 tweeters- silver METAL faceplate original version. SOLD
1- JBL LE20-1 early alnico cone tweeter (as used in L88, L55, etc) $50
1pr- Bozak B200Y aluminum cone tweeters- some small dents in aluminum, work fine. 8 ohm. $30 for the pair.
MIDS:
1- ADS 206-0217 1.5" dome midrange. Works perfectly, in very good shape. $35
1- ADS 206-0201 2" dome midrange. Works perfectly, some fuzz/dust on dome coating (normal for these with age). SOLD
1- Boston Acoustics 5.25" midrange, stamped-steel frame. Fresh refoam. Circa 1990s. $15
1- Philips AD5061-M8, with whizzer cone, fabric surround. $20
WOOFERS:
1- Acoustic Research AR2/AR2A 10"- early style alnico/cast frame. $40
1- Boston Acoustics A40 6.5" woofer- paper cone, early style. Fresh refoam. $20
1- Boston Acoustics CR9/CR400 8" woofer, NOS in box, $40
1- Boston Acoustics HD7 7" woofer. Refoamed about 18 months ago (used spliced foam, this one was done before the special foam became available, but it specs out fine). $25
1pr- Boston Acoustics T930 10" woofers. Fresh refoam. Work fine. SOLD
1pr- JBL 116A 8"- one fresh recone, one fresh refoam. $100 for the pair.
1- Gold Sound GS1044 DVC (dual 4 ohm). Fresh refoam. $30 Reduced from $35
1- Klipsch 5.25", poly cone, from center channel speaker, 1990s vintage, $10
1 pr.- Magnavox 15" from console. 1960. In extremely good condition. 4 ohms. SOLD
1- Polk 6503 6.5" woofer- SDA, Monitor 10, etc. 8 ohms. NOS. SOLD
1 pr. SEAS 25F-EWR 4 ohm 10", from Bang & Olufsen speakers. Similar to Dynaco A25 woofer, just 4 ohms. Great E-wave woofer. Video shielded/bucking magnet. SOLD
1- Tannoy Mercury M1/Revolution R1, 5" woofer (oval flange). $40.00
FULL RANGE/COAX:
1 pr.- Delco 6x9 car speakers. 10 ohm. Fabric surround, whizzer cone. Work fine. $15.00 for the pair.
1pr- Electrovoice 12TRXB, early version (alnico magnet, cinnamon color frame, paper-surround cones). $150.00 for the pair.
1pr- Eminence Beta 10CX, brand new. No horn driver (just woofer- can use any screw-on 1" horn driver) $105 for the pair
As almost always, I will entertain trades for good pro-audio or Econo-wave parts... compression horn drivers, Econo-wave-compatible horn flares, pro audio woofers, and such...
Gordon.
TWEETERS:
MIDS:
WOOFERS:
FULL RANGE/COAX:
Gordon.
