Manifold Enclosure for bass
No special considerations - it is just a vented box. Calculate the volume and port pretty much as usual.
The close proximity of all the drivers may add a bit of loading, so tuning a bit lower to start out could be a good idea, but it depends on what electronics and crossover frequencies you are using and how the response turns out.
GM
Joined 2003
No, per the shading on the drawing it shows a solid back and open front, creating a 1/4WL vent pipe, and why its depth/area is key to its HF response, etc.. It's a design I've 'cloned' and it works quite well, just didn't know EV called it a manifold. It would be interesting to tweak the design to incorporate a Karlson coupler to increase its HF response high enough to XO to a mid horn.
GM
