ok...well im looking to build 2 tower speakers out of peerless drivers.
I want to keep my budget at 100-120 bux for all the drivers for both towers not including anything else.
http://www.partsexpress.com/webpage.cfm?&DID=7&WebPage_ID=137#dome
Well theres a list of all of peerless drivers from partsexpress, which is where they will be purchased from.
BTW: Most of the bass is taken care of by a tempest in a 214 liter ported box, tuned to 15.4hz.
If you are looking into Peerless drivers, Bob Brines made a great pair off of Peerless TL speakers based off of Martin King's mathcad files ( www.quarter-wave.com ).
His website is at:
http://www.geocities.com/rbrines1/
His Peerless Pipes page is at:
http://www.geocities.com/rbrines1/Pages/Peerless_Pipe.htm
His Construction page is at:
http://www.geocities.com/rbrines1/Pages/PP_Construction.htm
I heard them at the DIY2002 Atlanta event, and they were one of the best sounding speakers at the event. The only fault was that the tweeter was a bit harsh, but the bass was there quite nicely, and it was pretty flat. The series crossover that he uses works quite nicely.
It is a good speaker design and not too expensive using the peerless drivers.
Brian
His website is at:
Brian
WhiteBoyChriss said:well i want it for highs...not bass
Well.. I was just commenting on the bass was good, but overall, they were very good speakers, considering the overall cost put into them. I want to make a similar TL design using SS 9500 tweeters and 8545 woofers.
Brian
the 8545/9500 are an older generation.
there are lots of new drviers out there that might be better.
one option might be (since we are looking at SS) a 2.5 way using the 18W/4531, 15W/4531 and R2904/70000. the only thing i dont like about these drivers is their low impedance. you might have some real low impedance in a 2.5 way
a cheaper alternate can be found at
http://www.d-web.com/dbrown/db61tl.htm
hope this helps.
hope this helps.
I have an idea!
For the midbass in my sats. i could use one of these for each sat....
http://www.partsexpress.com/pe/pshowdetl.cfm?&PartNumber=297-600&DID=7
For the tweeters in my sats. i could use one of these for each sat...
http://www.partsexpress.com/pe/pshowdetl.cfm?&PartNumber=277-406&DID=7
And to make a center channel with 2 of these...
And one of these...
Well give me sum feed back on what you think of my idea, or an idea of your own...and what crossover would i use for these setups.
And one of these...
driver combination
The difference in sensitivity of the drivers make them a poor combination IMO. I think A dome tweeter will match better with woofers in the 5-6" range. If you are not totally set on using a peerless tweeter, I would recommend the audax dome tweeters in the same price range. Hope this helps,
Austin
Austin
well then help me out...give me a good combo that will work together good (from partsexpress)
these also cought my eye...think that would be a good combo?...or am i better off making my own?
http://www.partsexpress.com/pe/show...4&St3=54681632&DS_ID=3&Product_ID=16226&DID=7
i would like to make a pair of towers, with the spk being peerless.
i'd like a 3-way with one tweet and two 6.5. one would be midrange and the other would be midbass. now the thing is i 'd like the bottom 6.5 midbass to have a divider between it and the other two spk. hight i would like ti keep around 3.5-4ft tall.
if anybody can give me sum sites that would be awesome.
THANKZ
THANKZ
- Making tower spks. with peerless drivers
