B+ =300VDC
Set cathode bias resistors to 680R.
Tubes will work under the conditions they're being forced to work under for as long as it's within their limits.
To have them work optimally you'll always need to do some work for them first.
EDIT: Aborting the Tai-Kwondo circuit....Too easy.
B+ =300VDC
i tried12bh7s in the second position and they seemed to work fine. B+ @ 260 and 430r at cathode. if i remember right that produced approx. 7 ma. i also tried them in first position but had trouble with microphonics. a higher stopper value may have helped. they sounded pretty good though. i had popped them in just to see how they'd do, but didn't do any experimenting as i was focusing on the 12au7 into 5687 at that time. maybe soon i'll try the 12bh7s again as i have a small box of them.
JojoD818 said:
2. If the usual input section is run at 5mA current, how do I calculate for R1 and R2?
from 6SN7/12SN7 datasheet and your 300v B+ (meaning each tube would see about 150v), running the tube at 5mA would result in a bias of around -4.2v.
this should give 4.2/5mA = 840R cathode resistors.
thanks for the input!
I hope to start it by next week, still doing some case work.
selfwilly said:i tried12bh7s in the second position and they seemed to work fine. B+ @ 260 and 430r at cathode. if i remember right that produced approx. 7 ma. i also tried them in first position but had trouble with microphonics. a higher stopper value may have helped. they sounded pretty good though. i had popped them in just to see how they'd do, but didn't do any experimenting as i was focusing on the 12au7 into 5687 at that time. maybe soon i'll try the 12bh7s again as i have a small box of them.
Interesting, I have the 12BH7 in my first position and 5687 in my second. Both tubes have 330R in the cathodes at 260VDC B+. I think the 12BH7 are flowing around 11ma and 5687 are about 13ma. Not sure if these are too much but right now the sound is a little thin on the bottom end. There is not enough grunt in the mid and lower bass. The mids and highs are sweet but not quite enough depth. I need to play around a bit or even try a different first tube if I can't get this combination to work. Will keep playing...
my impressions of the 12bh7s in first position were based on a very short audition that was compromised by the microphonic issue i had with them. i seem to remember them being very bright as well, but clean. the measurement for current i gave was for tube in second position. the B+ was a approximation from my iffy memory. i have a aikido set now with 470r in first and 330r in second position. i'll take some readings tonight with the 12bh7 and see what i come up with.
selfwilly said:i haven't done the experiment with the 12bh7s yet, yes i do reference the heaters to a voltage. i used @ 50 volts for my 6dj8 to 6922 and that worked fine. was very quiet. i plan on doing the 12bh7 experiment tonite, i'll post all details soon.
I'm having troubles with my aikido with all E88CC (same as 6922), I have some noise (like a hiss) at the output.
Could you please tell me the values you used for yours? (B+, Rks, etc.)
Andrea
Not uncommon with E88CCs, they can become noisy overnight.
Do you have a couple of USSR 6922s to try?
Hi Frank,
I have some CV2492 and ECC88.
The former had slightly less noise but high microphonics, the latter had almost the same hiss.
BTW I also tried some 6h30 that behaved similarly with in addition a series of clicks (more like a "ping") in the first minutes.
Cheers
Andrea
Cheers
Andrea
Hi Andy, B+ was at @ 210. i tried many settings between 200 to 225. all worked ok. I used 470r on first tube and 330 on second tube. I applied 40-50v to the filament tranny center tap. mine is a two chassis preamp. power supply on seperate chassis.
ONE NOTE: this may pertain to you it may not, i have found that all the variations i tried had way too much gain for my amps. exaggerating any noise or hiss issues that there may be. also could barely use aikido volume pot with out it becoming too LOUD
. i had to install 100k attenuators on my amps and back them off. voila' hiss is gone or minimized, and i can actually turn up my aikido volume control to 11 oclock befor it gets to loud! i use 99db horns.
charlie
charlie
selfwilly said:Hi Andy, B+ was at @ 210. i tried many settings between 200 to 225. all worked ok. I used 470r on first tube and 330 on second tube. I applied 40-50v to the filament tranny center tap. mine is a two chassis preamp. power supply on seperate chassis.
charlie
Hi Charlie,
thanks for the reply.
I had already thought about attenuating the power amp but wasn't sure it was a good idea.
Maybe a step-down signal transformer might do the trick (lowering at the same time output impedance).
The only problem is that I have no clue about which trasformer could be employed.... suggestions? (not costing a arm and a leg)
Cheers
Andrea
You know what I'm going to answer, right?
Just like any other SRPP circuit PSRR is pretty much inexistant.
is it really necessary to regulate the psu for the Aikido?
- Tubes / Valves
- Making sense of the Aikido calculations?
