Maida Regulators Redux
drj759 said:
Eli,
Don't know if the following is critical to your application:
The LR8 datasheet specifies a minimum of 1uf on the output to maintain stability.
Jackinnj suggests bypassing the adjust pin here: http://www.diyaudio.com/forums/showthread.php?postid=1112318#post1112318
Dave
A 1.5 muF./250 WVDC metallized polyester part will be at the O/P. Stability is a non-issue.
What's a good value for the adj. pin bypass? Is 10 nF. enough?
Joined 2006
Eli,
I dusted off the LR8's that I haven't had time to play with and I experimented a bit with the adj pin bypass. I definitely would recommend using a 10uF across the R2 (the lower voltage set resistor) to bypass the adj pin.
I saw about 1.5 mVp-p hash on the LR8 output without the 10uF adj pin bypass. The hash dropped to less than 0.5 mVp-p with the 10uF cap.
Did the experiments at low voltage, 16V in, 5V out. A 1uF poly was used on the output of the LR8. The LR8 output was connected to a JFET configured as 3.5ma CCS load.
Dave
drj759 said:
Eli,
Dave
I was making up parts order lists this A.M. for the owner to act on. 2X 10 muF./250 WVDC 'lytics to serve as adj. pin bypasses are on a list. ;)
Being anal, I've called for 2 protective diodes on each regulator. No prisoners are being taken. Since this is a low current situation, saying the PSU will roar (like a lion) is inaccurate. However, this PSU design will howl, like a scorpion mouse. :D
