Clearaudio use ceramic pipe.The ceramic shaft has no ball bearing at the top side.
I will use this bearing in my DIY project. It seems like the work will take a lot of time, and of course I will publish some pics.
Master reference's platter height 80mm, weight ~8 kilogram , out limiter clamp ~1,5 kg, record clamps ~0.3-.0.4 kg total weight ~ 10 kg
After replacing CMB bearing platter literally float on air.
Watch this video
http://www.youtube.com/watch?v=EJOKzC3QJW8
http://www.youtube.com/watch?v=9GqIoMqqkys
Watch this video
Thanks for the pigs. The video’s are quite impressive. It floats on air. Seeing this video I think I have to redraw my earlier remark that a magnetic bearing has no less resistance than a inverted bearing. And afterwards resistance is mostly heat and noise. So less resistance, less noise.
Can you estimate how many mm the magnets are apart from each other with platter and record on top?
W:~1,5mm Radius:2,5cm
YNWOAN said:Excellent, many thanks
Could I also ask how far appart they are before the weight of the platter is on them?
~11mm.
electromagnet
Why don't we use an electromagnet as the static (bottom) magnet? Then the strength of the magnetic field can be easily varied. We then can easily measure the difference in wow and flutter with varying pressure on the thrust plate. Would be interesting.
This of course leads to the question: is it possible or even easy to design a circular electromagnet. Will the magnetic field be more homogeneous than with a static magnet or the opposite?
Marco
The only way to have any control over this issue is (as far as I can see) to use a method similar to my own - I ring magnet and a second array of individual cylinder magnets set into a ring shape. By increasing, or decreasing, the number of individual cylinder magnets used one is able to customise the strength of the magnetic field and match it to the mass of the platter.
Marco
Marco, why don't you try it and let us know the results?
I'm investigating this. Up till now I can't find much info on making circular electromagnets and how to work on the homogeneity of the magnetic field.
But it's interesting because it seems to be new territory for turntables.
MArco
MArco
No it's not new territory. Tim De Parvacini of EAR has been working on it for years, in fact I think he still hasn't ironed out all of the issues with his design.
That's what I call "new territory" .
It proves to be quit difficult to make a large ring electromagnet to carry the platter. Now I'm thinking off an circular array off small electromagnets.
If I put 20 small super magnets under the platter, and 20 small electromagnets on the base I could even drive the platter with a approx. 10 Hz AC signal. I'm affraid that that would give nice unwanted resonances in the vertical so at first I'll try with DC electromagnets (or even normal super magnets).
MArco
What about two concentric rings: a stronger one for lift, and a weaker one for driving the platter?
Regards.
Aengus
Yes, and then angled so that one is lifting, and one is facing inward:
(+ = a magnet field; -- or | is a magnet . is a placeholder for this drawing)
Tempting, very tempting, but a lot of work.
MArco
- Analogue Source
- Magnetic turntable bearing
